Sony PlayStation 2 (PS2) Console Logo
Posted on Nov 16, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
System is PS2........ Controler is PS3 usb.....
I recently brought a controler ( PS3),I was told it would work fine with PS2 console usb. It does'nt.
Is there a converter ?
Thanks Michael
Anonymous
Level 1:
  • Contributor 59 Answers
  • Posted on Nov 16, 2008
Anonymous
Contributor
Level 1:
Answers
59
Questions
0
Helped
18800
Points
91
Hii there,
well dude it will surely work but not with the usb you wud have to make the controller the part of u r network in the same way as u did for the ps2. just set the network as a secured network as well ...
ZappaNut
Level 3:
  • Master 960 Answers
ZappaNut
Master
Level 3:
Answers
960
Questions
Helped
308403
Points
2820
Yes , it is called a PS3 .
The PS3 stuff works on the PS2 , but not the other way around.
Connect controller using USB message
Your controler is either low on battery charge, or it needs to re-sync with the system.
If you still have the message while it is plugged in, then either the plug is worn, cable has worn out, or it is the wrong kind of USB cable. Some cables do not have a data connection and although they may work to charge the controler, they will not work to sync the controler to the system. Make sure nobody switched your cable for the kind used only to charge cellphones, as USB charger cables do not usually have the data pins enabled.
If it is the correct cable and works for other PS3 controlers, then it could be a worn socket on your controler and no way to really fix except to buy a new controler.
Another, more rare possibility is something wrong with the controler internally, which can sometimes be fixed by using a small pin, like a safety pin and pressing it into the tiny "reset" hole on the bottom of the controler, while it is plugged in to the USB cable and PS3., then pressing the PS3 button on the controler to make sure it's powered on during reset. The "reset hole" is very small, but can be found closest to the screw nearest where the cable plugs in, on the bottom of the controler.
Ps3 controller not connecting
Solve all your PS3 issues with a free guide from the site just for visiting. Its very helpful for all PS3 owners. Hope this helps out
Ps2 controller won't work with our new ps3
Of course, ps3 can not be used on the ps3 controller. Can not be mixed used.
Or you can dial the Sony service center for advance information, it's better.
electronis wholesale
I did quick settings system restore, and now it is trying to start up, but I cannot get past the "connect controller using usb cable and then press ps button" page. My controller is connected and was...
chances are that u need to get ur controler linked to ur ps3 just connect a usb from the ps3 to controler hope this helped also
Their is a problem with psn accounts their updating servers so be patient
Ps3
hook up usb for controler into ps3 then controller then hit ps button also use cords ps3 came with first with back power on but on stand by hold power button down for 10sec this should connect the controler to system as well as give you picture if it dosent check your tv with another device such as dvd player make sure the hook ups work
Ps3 doesnt recognise both controllers
conect the usb cord to ps3 and hit ps button on each controler to link them to system after conecting the usb cables to controler
Ps2 on ps3 game problems
I also had this problem running PS2 games. I noticed that when it happened, my bluetooth remotes becames unpaired and could no longer be used to turn the PS3 on/off. Pressing the PS button would not interrupt the hung PS2 game (i.e., it would not give me the options to quit the game, turn the system/controller off, etc.). I talked with the Sony Playstation folks and they suggested resetting the bluetooth controllers (by poking the hole on the backside next to the screw hole). They said sometimes the bluetooth info gets honked. Just before this problem popped up, I was messing around with pairing a bluetooth headset and may have interrupted the pairing. You may have a similar situation, so try resetting your controllers. You may have to plug into the USB port if they won't re-pair after resetting (I did). Good luck!
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
