2001 Mitsubishi Eclipse Logo
Anonymous Posted on Apr 22, 2012
3G Mitsubishi Eclipse Climate Control Light Bulb Replacement
How do you replace the burned out light bulbs of the 2001 Eclipse climate control unit in the center of the dash (below the stereo unit). I have tried to remove on a practice unit (junkyard), and ended up breaking the 2 knobs while trying to remove them.
Fickster
Level 1:
New Friend:
  • Contributor 37 Answers
  • Posted on Apr 26, 2015
Fickster
Contributor
Level 1:
New Friend:
Answers
37
Questions
0
Helped
13046
Points
88
The control panel for the heater and A/C must be removed. Suggest you get Chilton's manual from the library. It will take you through step by step with pictures. To summarize: 1) Remove trim panel covering radio and heater controls. 2) Remove radio. 3) Disconnect the two heater control cables from the control panel. The trick to removing the cables is to compress the "claw" spring holding the cable by pressing a screwdriver from the underside of the control panel to release each cable.4) Remove control panel. Take to a workbench. From the backside of the control panel at the top, notice two large holes through which you can access the V2 Toshiba bulb holders. Turn them a quarter turn to remove them and the bulbs. The bulb is a common #74 bulb.
5 Related Answers
davidraywork
  • 35 Answers
  • Posted on Jul 02, 2009
SOURCE: brake light bulb Mitsubishi Eclipse Cars
look for access panels in rear hatch there will be one on each side remove those and there will be 10 ml nuts holding the light housings on remove those then you can access the lights
Anonymous
  • 3 Answers
  • Posted on Nov 22, 2009
SOURCE: Can't move the climate control knob to hot
There is a technical service bulletin for this problem.(tsb# 05-55-003) The blend door inside the heater box is binding and needs to be replaced. Unfortunately, the dash has to be removed and the a.c. refrigerant removed in order to remove the heater box.
I already have purchased the blend door and the linkage for my son,s 2003 Lancer. I will be doing the job in about a week.
I am a professional auto repair tech with 38 years experience. I would not recommend doing this job yourself unless you are pretty good with auto repair work.
Anonymous
  • 834 Answers
  • Posted on Apr 23, 2010
SOURCE: dash light
It sounds like the headlight switch is bad.
Anonymous
  • Posted on Feb 06, 2011
SOURCE: I bought a 2004 Lancer
i bought a used 2004 mitsubishi lancer ls sportback with the same problem. a google search told me this was a known defect and was covered under a dealer recall--no cost to me. my local dealer did the job. it took at least a half day--the entire dash, they said, had to be removed. the fix isn't perfect, but it is light years above and beyond what it was b4. the new knobs aren't silky smooth, but the old ones needed tools to turn!
Anonymous
  • 53 Answers
  • Posted on Mar 16, 2012
SOURCE: 2002 mitsubishi lancer: the knob on the temperature side of the climate control broke off.
Then you have to replace the temperature control it's self Johnny
Should 2004 Cavalier's climate control knobs & power window buttons light up. ? I'd like to replace the bulb or fuse if its possible
The bulbs in the control head for the heater/ac are nor serviced by GM but I think you can purchase them at radio shack if you can get the head out and apart I am pretty sure you can replace them.
Replace heater control panel bulbs
1. use old bulbs as samples by gently removing them with a soft cloth.2. Go to autopart shop or walmart,target or Canadian tire and you will find replacement bulbs. 3. Make sure you mark or place each old bulb into an envelope so you know where to put the new bulbs.
5helpful
How do I replace the light in the dash for the heating knob ( vent, defroster, etc)
The tiny incandescent light bulb is behind the knob soldered to the circuit board, you must remove the climate control head unit and take it apart to access the knobs back light bulb on the circuit board. You can buy the replacement bulb at Radio Shack, the part number is 7219 Micro Lamp.
1helpful
2answers
I just bought this car. Is there supposed to be a light for the climate control? It is not illuminated in the dark when the lights are on. Just don't know if this is normal or a light or fuse?
It is supposed to be illuminated. It may be a fuse or a bulb inside the climate control module. You can call the dealer and they will tell you if the bulb is replaceable or if the entire module must be replaced.
2helpful
How to remove 2007 jeep commander climate control panel for light bulb replacement
The lights in the climate control panel are not bulbs, they are LED and the entire panel will need to be replaced. I would check for a bad connection before replacing the panel assembly.
2helpful
2answers
Display on climate control screen is out and i don't see any type of description on fuse panel that fits this problem. AC, heater, fan, everything else works but the display.
U must remove the climate control unit from the dash and remove the top cover of the unit, u will find a tiny twist in light bulb socket with a tiny little light bulb, this provides the backlight for the AC/heater display, u can buy the bulb at any auto parts store, couple of bucks.
2000 VW Passat Climate control Switch panel lights out
Is the light bulb replacement the same for 2000 VW Cabriolet?
Ac switch light
Illumination Bulbs — A/C Switch
Removal
  1. Disconnect the battery ground cable (14301).
  1. Remove the shift console panel. Refer to Section 01-12 for the removal and installation procedure.
  1. Remove the three climate control assembly screws.
  1. Disconnect the climate control assembly electrical connector.
  1. Depress the tabs on the air door shafts and remove the three climate control cable ends. Pull the climate control assembly from the vehicle.
  1. Remove the A/C switch electrical connector.
  2. Depress the tabs on the A/C switch and remove the A/C switch from the climate control assembly.Twist and pull out to remove the A/C switch miniature bulb from the A/C switch.
Climate contol does not light up.
Unfortunately the bulbs that light up your climate control are not replaceable and in order to get it to light back up again you need to replace the climate control unit.
Top Mitsubishi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Mitsubishi Expert? Answer questions, earn points and help others
