SOURCE: Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
SOURCE: The ice maker in my
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
SOURCE: whirlpool gold ice machine not working
One possible problem could be that the gear pins have broken off. The underside of the gear has contacts that turn on the water pump. The gear is not making an electical connection to these contacts could be the cause of your ice maker not working.
SOURCE: Whirlpool gold refrigerator ice maker
Check the filter at the supply, and there is another in the control valve. Test flow from the control valve. I make a test power cord for the control valve and see how much water comes from it. It should squirt good, and shut off completely.
SOURCE: Whirlpool Gold Side by Side Ice maker not making ice.
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in
it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let
it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then
try the water dispenser. The water should go to the ice maker. This will tell
you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice
maker needs water. If the valve doesn't seal good because of sediment or wear
it will continue to drip and when the water reaches the ice maker supply tube
it will freeze. You can take the water
line off the valve and watch to see if it drips.
Please provide model number and additional descriptive information if possible.
well the ice maker cycles water but just not getting cold enough what do i do?
if the machine is not getting cold enough for the ice to freeze then more than likely you have either a sealed system issue(freon) or the machine is over heating due the condersor fan motor isnt runnning
