Look for the brand name of your modem and model. You can find it in the box of the modem. If you have it then go to there website in the internet and download there the driver.
To find and install the driver for the simple
communications controller:
Go to Device Manager and click on the pci simple
Go to Properties and then Details. You will see a code like
PCI/VEN_8086&DEV_27D8&SUBSYS...
The VEN code means vendor and the DEV code means device: in the example the
vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get
the name of your hardware.
From there, you can search for a driver download for your
hardware
download 50000 pc drivers for xp from torrentz/mininova make sure u have either bitlord or utorrent installed on ure system 1st
when download is done move folder from in downloads to your desktop now open up device manager goto the pci device needing driver should have yellow question mark at it and tell the pc to search your desktop and it should hopefully find it in the folder when done delete folder and make sure your not running utorrent/bitlord as you will be shareing this file with others
To find and install the driver for the simple communications controller:
Go to Device Manager and click on the pci simple communications controller
Go to Properties and then Details. You will see a code like PCI/VEN_8086&DEV_27D8&SUBSYS... The VEN code means vendor and the DEV code means device: in the example the vendor is 8086 and the device is 27D8.
Once you have the two codes, go to www.pcidatabse.com. Enter the two codes and you should get the name of your hardware.
From there, you can search for a driver download for your hardware.
