Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
I have A craftsman Model 917.273470 with a Kohler 20 Hp V-Twin. It will run if I spray gas in the carb. Drained old fuel, replaced fuel filter, checked gas flow into carb with pressure guage, Cleaned
Craftsman Lawn Tractor 20.0 Hp, 42" Mower Electric Start. DLT3000 Kohler V-twin
    Brigadier General:
  • 6,468 Answers
Check the solenoid on the bottom of the carb check for movement and power if it moves and has power open the carb and clean it
Posted on Apr 19, 2012
5 Suggested Answers
6ya staff
SOURCE:
Robert J Gordon
  • 11 Answers
SOURCE: I have a Craftsman 42 in. 15.5 hp lawn tractor
check an see if the cabuerator is getting fuel and check make sure sparkplug is getting continous fire from the coil
Posted on Sep 13, 2010
savannah_316
  • 19 Answers
SOURCE: Problem for Craftsman 20 hp 42 in. Deck Lawn Tract...
the bar connecting the wheels is bent. this is easy to change. just pull the pins out on both sides and lift the rod out. you can straighten it in a vise or order a new one through sears. cost about $12. our local repair shop keeps them on hand.
Posted on Aug 09, 2010
Anonymous
  • 130 Answers
SOURCE: change the v-best on a craftsman 42' mower 6 speed transaxle lawn
if your going to do this get a book its not going to be easy.so you need a book i say take to shop.let me know
Posted on Jul 22, 2009
philwalker78
Phil Walker
  • 608 Answers
SOURCE: My mower has a V twin engine... The engine wont
Has your mower got a fuel cutoff solenoid in the bottom if the carby? If so you need to put your finger on the solenoid and turn your key from off to on and you should feel the solenoid click. If it dos'nt the solenoid may be faulty or the wire going to it may not be getting 12 volts. Check this wire for voltage with a test light or multimeter. Let me know how you go or if it has no fuel solenoid. Regards Phil.
Posted on Apr 21, 2011
Testimonial: "Actually That was my thought, but didn't know how to ck the part it self. Thank you"
Why wont my 12.5 hp kohler engine not run full throttle and loss of power
it sounds like your carb is gummed up. You can TRY something called SEA FOAM (you can get it from Napa), you put it in your gas tank. It's the poor man's tune-up. Otherwise, you can get some spray carb cleaner and pull off your air cleaner and spray it in there. Hope that helps.
Jul 17, 2014 | Cub Cadet Garden
Craftsman Kohler 26 hp starts and runs for 10 seconds with starting fluid sprayed in the carbureator then stops. How do I keep it running
first you need to see if you have fuel going to the carb then you need to see if it is going threw the carb there is a solenoid on the bottom of the carb that shuts fuel off to the jet if you have no power to the solenoid that will keep it from running also dirty old fuel sitting in the carb will cause the carb rto stick closed so if you have power to it remove it and see if it is opening
Jun 14, 2012 | Craftsman 26 hp 54 in. Deck Deluxe Yard...
I have a 2007, 6500 Craftsman tractor with 26 hp engine (kohler) that won't start. The tractor was running (old gas) when we got off it for a few minutes then went back to start it again but it would not...
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
Jun 11, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
Lawnmower sat up for a season would not crank replaced sparkplugs air filter fuel filter hose fuel pump is pumping gas to carburator but still will not start unless you pour some gas into the carburator or...
If it will start when you pour gas then its a fuel problem on some of these they have a screw at the bottom of the carb remove that and see if you have bad fuel. If that does not work then remove the carb and service it may just be a stuck float or something
Aug 09, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftsman LT1000 with a B S 20 hp twin motor. Recently it started backfiring after it runs for about 10 minutes. Only after it's warm it backfires. I changed the oil and filter, plugs,fuel filter...
Carb is running a tad rich and the fuel collects in the muffler. My 20 twin has done it since I bought the thing and that was almost 8 years ago.
Cut the engine idle down before you cut the key off and minimize the bang.
Someone else may give a better explanation of the why but it is just annoying and personally after rebuilding the carb and checking the fuel pump on mine it still does it on occasion. Hasn't hurt a thing on in all these years and I actually thing it blows the soot out of the muffler when it does.
Jun 09, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
27 hp kohler v-twin ohv backfires, and @ times blows white or black smoke
SOUNDS LIKE IT HAS BAD GAS AND THE VALVES NEED RE SET YOU MAY WANT TO FLUSH YOUR FULE AND CLEAN OUT THE CARB LET ME KNOW IF THIS HELPS
Oct 08, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Cleaned gas and changed fuel filter. Mower only
There are a number of things that can cause this, depending on the engine fitted. Assuming a Briggs & Stratton V-twin...
Check that the carb solenoid under the float bowl is connected, has battery voltage when the ignition switch is at 'RUN', and is functional.
As a quick check, with the engne OFF, turn key to 'RUN' there should be an audiable 'click' from the carb if the solenoid is working.
After that, check that the fuel pump is delivering fuel (disconnect output, and crank engine). SHould be a good flow.
Oct 01, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a craftsman gt 6000 with kohler 18 hp magnum today it started fine and ran goodd for over an hour i put gas in it and ti would not stay runing it stated surging and popping and cuts off
Your carb is full of trash. you also probaly need to clean out the bottom of your fuel tank, blow out your lines and replace the fuel filter. I have 2 mowers with kohler engines and clean out the fuel tanks fuel lines and carbs 1 time a year. There is also a fuel shut solenoid on the carb this is normally problem if the engine does not run. but I am certain your problem is a simple fix, all you have to do is clean everything out in the fuel system.
Sep 13, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have a 20 HP twin cylinder KOHLER engine on CRAFTSMAN mower.
If you are able...have someone do a compression check on the engine. Usually if a mower is loosing power and it is a twin cylinder engine, one of the headgaskets may be blown.
May 27, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,121 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
