There is spark & fuel. Any ideas?
SOURCE: 200 YAMAHA V-STAR 650 HAS
IT sounds like it is the pickups not working (.telling it to spark) if not then it will be CDI UNIT OR ENGINE GENERATOR COILS
SOURCE: why wont my suzuki bandit 250 start?
If you tried to start the engine for any length of time, the plug would be damp and smell of petrol because fuel was being drawn into the combustion chamber. Without spark to ingnite the mixture, it would cause the plug to become damp. I am assuming you fitted the correct spark plug and that it is gapped correctly.
I don't mean this to sound foolish, but I would suggest you make certain the emergency kill switch has not been accidentally switched off. Also, if you have a sidestand safety interlock that prevents the engine being started while the side stand is down, flip up the sidestand and try again to start it.
Additionally, to make sure the plug wire is securely fitted to the plug. It is possible that the inside of the plug wire cap has gathered moisture and may need to be wiped dry.
If none of the above suggestions solve the problem, remove the plug then reconnect it to the plug wire and hold it near the cylinder - but not near the plug hole in the cylinder head (fuel vapors) - while pressing the starter . You should see an obvious spark. No spark likely means the coil is faulty.
SOURCE: Suzuki vs800 intruder dies after about a mile!
Sounds like water in the gas.
ALWAYS have a fire extinguisher on hand when working on carburetors.
For each carb > Drain the carburetor. There should be a screw on the lower side or bottom of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Put the carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
SOURCE: 1991 suzuki intruder 1400 starter cranks strong but won't start
the battery will build up calcium and wont hold enough kick charge to start bike thou the battery will test ok in this instance,, this happens when a bike sits for a while without a start
hpoe this helps
SOURCE: 2000 yamaha vstar 1100 custom. starter problem?
I had the same problem 2001 XVS1100 Custom
this is a starter issue Over time the starter on this bike twists when its under a load.
Look at the two bolts holding the starter on if they are not straight across then its twisted. turn starter back in line with a pair of big channel locks and try to start this should do the trick if this works i would recommend taking the two bolts out and bend them back straight or replace and reinstall starter this should fixya problem
Hope this helps ...............Jimmyfixya
