Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
My Craftsman tractor w/ kohler 15.5 HP runs for approx 45 minutes, then it stalls. I check the fuel filter bowl and no gas is getting thru from the tank to the filtter. I let the tractor sit for 10-15 min and the bowl filter bowl fills. I can then run until the bowl empties agiain. I disconnect the fuel line and the fuel runs right out?
    Habit-Forming:
    New Friend:
  • 89 Answers
Check the gas pack as mentioned above. If not check down the line for any leaks , air or fuel. Also check the "needle" on the diaphragm inside the carb. And or the fuel jet settings.
Posted on Nov 02, 2017
  • 5 Answers
It may be that the gas cap no longer vents, allowing air to enter the tank as gas is being used. Try to have cap loose to see it it is the problem, and if it is, a very small hole on cap needs to be opened or made.
Posted on Nov 01, 2017
6ya staff
SOURCE:
josh1111
  • 398 Answers
SOURCE: 2002 craftsman 23 hp kohler pro series stalls and wont restart
try playing with the throttle adjustment or it could be a saftey feature malfunction, like the seat shutoff for example.
Posted on Feb 26, 2009
Anonymous
  • 16 Answers
SOURCE: My tractor stalls like it is starved for gas
I had a similar problem with a sears tractor. close to the carbarator is a rectangle box with a rubber hose going to the engine block - remove the hose and spray carb cleaner in the hose wait a few mins and try again - its a vacuum for the carb
Posted on Jun 04, 2009
Anonymous
  • 33 Answers
SOURCE: Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Posted on Jul 04, 2009
dewey wyatt
  • 202 Answers
SOURCE: craftsman garden tractor stalls after running for about 20 minute
do you have the right fuel filter? some are for pressure and some are for gravity feed, the pressure type (fuel pump) wont flow the gas correctly. another possibility would be the coil.
Posted on Jul 07, 2009
dsitar
  • 5 Answers
SOURCE: My Craftsman Lawn Tractor 18 HP Briggs and
I had the same problem and talked to 3 different techs. The only solution they would come up with is to replace the carb. I didnt believe this was the problem. If you have a fuel solenoid on the bottom of the float bowl remove it and just put in a float bowl plug that threads in. I just taped up the solenoid connector. It runs better than it ever did. I believe the solenoid gets hot and starts shutting off the fuel. I used a plug from a spare set of 1977 yamaha motorcycle carbs I had sitting around.Go figure. Hope this works
Posted on Aug 01, 2010
Craftsman lawn tractor model no.917.289101 stalls out
Stall or quits? Will it run 15 minutes again after it cools down. Check
carb bowl for water. Loosen the bottom screw a little until gas come out and water will "roll" off the gas that drops out on the deck.
May 21, 2012 | Craftsman Garden
I have a 2007, 6500 Craftsman tractor with 26 hp engine (kohler) that won't start. The tractor was running (old gas) when we got off it for a few minutes then went back to start it again but it would not...
First check fuel shutoff valve on bottom of carb . Disconnect and remove , clean witn carb cleaner and be sure there is power at wire when the key is on . Also clean carb jets and bowl .....
Jun 11, 2017 | Craftsman 26 Hp 54" Deck Yard Tractor
My Craftsman Lawn Tractor 18 HP Briggs and Stratton runs about 10-15 minutes and then stalls. Will restart after a cool down period, any ideas?
Jun 26, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 16.5hp 42 in. Mower runs for about
mine always starts-- and won't start again if I turn it off- going to try the flywheel key replacement-- which affects the timing-- otherwise-- let me know what you find out as a solution
May 24, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Riding lawnmower wont run long
Check for dirt in gas tank some times stuff will fall in when filling and block the hole in bottom of gas tank and wont let gas flow clean everything out and see if it works. Also check that all kill switches are tight and not moving.
Oct 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftmen tractor w/ Kohler engine stalls out continually
Sounds too lean.
Can you cover the air intake with your hand 90% or use the choke a bit and then load the engine to see if it runs better?
If you ever find a carb with manual high and low mixture adjustments that will fit yours......put it on and keep it on.
You can usually get then from older tractors.
Aug 25, 2009 | Craftsman Garden
Craftsman garden tractor stalls after running for about 20 minute
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Feb 25, 2009 | Craftsman Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
93 people viewed this question
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
