This is generally an indicator that either the door was left open too long, dirty condensor coils and/or you have a issue with the condenser fan mtr not running or blade is jammed. pull the unit out and see if the fan in the back is running if not or if it is running slowly then it needs to be replaced ASAP!!!! This fan is design for two purposes to cool the compressor from over heating and to draft cooler air across the condensor coils and displace heat outside unit
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
I have checked all above. It appears compressor And /or fan is working. Door not ajar, cleaned all dusy from front access coils. No cooling at all
