Have an older Reddy Heater Pro 110. Some years ago it was being used and ran out of K1 fuel while being used. If you plug it into the outlet (with a full tank of K1) only the fan works. Looking for suggestions about fixing the heater. I did take apart the heater and the only thing that I can see could be wrong is a black "box" under the fan (ignitor starter circuit) or somewhere there is a fuse or maybe a pump failure ? Has anyone had this problem ? Thanks.
Please answer the following questions. There are several folks on the board that can help but we need to know some vital information so we can get started. Answer these, if you can:
I'm having the same issue. I have a 110 pro, 110,000 BTU. It has a spark plug. When I turn it on the fan comes on and it blows kero out the front but won't light. I pulled spark plug wire off and checked to make sure I have juice and I do. It has always worked before.
I had the same problem with my r-110, it had always run good until recently. i would plug it in, and it would run about 10 sec. without igniting and shut off. here's what corrected my problem. pulled the spark plug ( an elongated spark plug) and checked the gap. it was about half of the recommended .070 gap. i hope this helps. craig
i have the exact problem with mine. model #r-110. fan motor runs but no ignition. what part or parts will get it fired up again. thanks craig
I have a pro 150 That has a spark Plug ( FI2150) and was working fine, I turned it off then went to turn back on and it runs but will not fire, I checked the spark plug wire with a spark plug wire tester and it has power and checked the fuel pressure @ 5lbs, but still cannot get it to start.
Any Suggestions
I have a reddy heater 110 with the same problem. Fan runs, plug shows fire but doesn't seem to be getting fuel. Fan runs a few seconds and then trips the reset.
I have a redddy heater 55 it has fuel spray& glow but it will not ignite.
We have a Reddy Heater 125T, would not fire up. Switch lights, blinks, we put a new ignitor into it and still will not fire up? Any suggestions?
Thank you
170t won,t light with top cover on
