SOURCE: How do u change the oil in a troy bilt lawn mower?
Set it up on a work bench or table of some sort with the dipstick at the outside edge of the table. Remove the dipstick and turn the mower on its side dumping the oil out the dipstick tube into a suitable container.
Don't do like my daughter did when I told her how to do this, she took a container that her dog had played with and bit holes in it, now she has a nice oily spot in her back yard LOL
SOURCE: Mulching blade replacement for Toro GTS 6HP
goto toro website and use model of machine to get blade model and use blade model in google to get prices and then order them
SOURCE: Troy bilt push mower
I know this is a dumb question, but is the blade on upside down? This is common mistake to make, and is the blade properly balanced and sharp. I would definitely make sure of these items first. From the way you describe it, I can't think of anything else.
SOURCE: LAWNMOWER EXPERT: I am able to partially pull the
It sounds like you you could have a motor problem but it could be in your drive system depending on model. You could have a stuck exhaust vavle or many other things. You haven't listed motor model or brand, but take the cover off the valves and see if they are moving. If your drive is driven off the main motor shaft with a belt, try removing this belt and see how well it turns. It could be your drive transmission not working properly.
SOURCE: replacement blades for Troy-Bilt chipper-shredder
The knife kit for the 47042 and 47044 Tomahawk Pro chipper is part number 1772231MA.
There are several for sale on Ebay or from a Murray dealer
