Fire Hazard? How can a rubber hose that drains water, be a fire hazard? This inspector is jerking you around. Since there are no copper fitting that will fit the connector, use a flexible stainless steel water water supply hose, that's normally used on an automatic washer. You'll wind up with 2 female ends, but that won't matter. Be sure there is a rubber washer in the end you connect to the unit's hose connection and only tighten it enough that it won't leak. If you over tighten it, it will crack or brake the plastic male connector.
Just for my own information, why is a building inspector necessary for the installation and approval of a portable dehumidifier? You can respond bu clicking on the Comment link. Thanks
As per your problem, that the dehumidifier shuts offautomatically - If yourdehumidifier froze, the compressor will shut off automatically. Allow the iceto melt before emptying the tank and restart the dehumidifier.
Hope this will help you. Good Luck.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
Unplug from wall. Take the front cover off and disconnect the 2 wires that attach to the humidity control dial. Plug back in. If it works, the problem is the humidty control dial (mine just went bad). With it unhooked, it will run constantly, but will still turn off when the bucket is full. To turn off, simply unplug.
Hi, There are many reasons for a dehumidifier to not work or collect water. Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
