Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
"Still No Power"
After replacing cp114, cp120, cp130 and cp 135 on my RCA D52W20, when powered on the green comes on along with a high pitch sound making several attemps to power on before completely shutting down and still no power. Please provide solution. Also, what pin hole should the negative side of the capacitor be placed in? Thanks for your time...
6ya staff
SOURCE:
ladywinn
ladywinn
  • 5138 Answers
SOURCE: Replaced the Capacitors, Still have a Power Issue
Resolder all the pinns on Flyback transfomer.
Posted on Feb 13, 2009
ABRsvcs
  • 4234 Answers
SOURCE: Rca d52w19 push power flashes 3 times
The caps in these sets rarely bulge. Try checking the Horizontal Output Transistor (HOT). I suspect that it is shorted. The noise you are hearing is the power supply attempting to fire. With the defect further on, the power supply will turn itself off as a safety valve.
Keep us posted,
Dan
Posted on Feb 21, 2009
Bill England
  • 18 Answers
SOURCE: rca d52w20
it should if you can get one most have been on back order. the board with the ihvt on it is the one to replace
Posted on Feb 25, 2009
Jack Olszewski
  • 12 Answers
SOURCE: I have a RCA D52W20 52" HDTV Ready TV which I
Unplug High voltage lead from HV splitter. This is a red wire going from HV transformer to similar (white plastic) device located up front, between picture tubes. Disconnect the one which is coming in, by strong energetic pull down with pliers. Leave those which go to picture tubs in. Make sure that disconnected wire is far from other components or metal parts (high voltage - SEVERAL INCHES SPARK CAN OCCUR) Turn the unit on - if different than 3 blinks - the splitter is your problem.
Posted on Feb 13, 2011
SD Tech
SD Tech
  • 14553 Answers
SOURCE: "Still no power". After replacing cp114, cp120, cp130 and cp 135 on my RCA D52W20B, when powered on the green comes on along with a high pitch sound making several attemps to power on before completel
The whine is a short somewhere---+ and - are marked on the board for each cap if it is polarized---usually the - will have a shaded white mark on top of board--if you got one in backwards it can explode......
Posted on Apr 13, 2012
Apr 13, 2012 | RCA D52W20 52" Rear Projection HDTV-Ready...
Our 52 inch RCA tv Model #D52W20 will not come on when we power it on. If we keep hitting the on button it will eventually come on. When it first started it would come on in about 10 min now it takes...
Replace the CP150, CP120 and CP114 Capacitors. You can get the RCA repair kit called the ATC221 CP150, CP114 and CP120 repair kit from www.tvrepairworld.com which contains the caps for the ATC221 and ITC222 versions of your model along with the CD with repair instructions.
Apr 25, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Feb 03, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
52 in rca rear projection hdtv wont power up power light flases three times
3 capacitors on the deflection board cp150,cp114 cp120 2200uf 16v use 25v 220uf 35v cp 150 most of the time is puffed up on top.
Dec 21, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 WONT TURN ON...GREEN LED ON /OFF THREE TIMES
LOCATION NUMBER CP114,CP150,CP140,CP120,CP130 ANY CAN BE BAD ALSO SOLDER LOOSE CONNECTION UNDER FLYBACK
Aug 28, 2009 | RCA HD52W58 52" TV
I have a D52W20 green light comes on 3 times but has no power.
Replace capacitors in power supply area
Replace capacitor cp150 (2200mf 16v ) capacitor CP120 and capacitor cp112
Replace this capacitor too: CP114 (330uf @ 35V )
Thank you
Aug 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52 inch D52W20 hdtv ready television
Replace 3 capacitors cp150- 2200uf 16v ////cp114 and cp120---- 220uf 35v. buy caps at Radio Shack.
Dec 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV will not turn on.
On the Deflection board check capacitor cp150- 2200uf 16v if it is puffed up on top it is bad,replace 2 other caps in same circuit also cp114- cp120 -220uf 35v. they are green with gold writing on them.
Dec 24, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca d52w20 52 IN
Bad capacitors on Power/deflection board cp150,cp114,cp120 capacitor cp 150 2200uf 16v, cp114&cp120 220uf 35v
Dec 16, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 in. Rear projection hdtv problems
can you tell me if the light blinks when you press power? If so let me know and I can help you diagnose the problem.
Jun 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
125 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
