Epson Stylus Photo R200 InkJet Printer Logo
A. Hardy Posted on Feb 17, 2018
Epson Sylus R300 Ink Cartidge stuck
I have an Epson Stylus R300. I have not used it in a long time, so I replace all the ink CartrIdge. I turned the printer on and the cartridge moved all the way to the right and got stuck under the lip part. No matter what I do, I can not reset it or get It to move. Please help Angela
  • Anonymous Apr 12, 2012
    Angela, what error appears in the printer driver software?
  • A. Hardy Apr 13, 2012
    The ink catidge is stuck. It will not move. I have check to see if there is paper stuck inside of it. I have turned it on and off many time, still the cartidge is not movinging. (stuck on the fare right hand side)
David Robbins
Level 1:
Habit-Forming:
New Friend:
  • Contributor 11 Answers
  • Posted on Feb 17, 2018
David Robbins
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
11
Questions
0
Helped
9497
Points
28
Had the same problem and found its a part underneath the cartridges. You have to remove whole cartridge carrier, it's the printer head that can pop up. Easy to pop back down but you have you remove top covers. Good luck.
3 Related Answers
Anonymous
  • 159 Answers
  • Posted on Feb 14, 2009
SOURCE: Clean "Waste Ink Cartridge" Epson R300
Had the same problem. (its a work around without removing the waste ink pad)
Took alot of work but I fixed it.
Frist thing you need to know that error means your ink waste pad is full. Its a $75.00 to replace but there is a work around it.
You will need this free app. SSC service utitlty.
http://inkjetprinterhelp.us/epsonSSC.html Its a great app.
Instrusctions are on the website there.
You will also have to Open the access panel on the rear of the printer (remove screw) and look inside carefullly with a flashlight. You will see a tube (down and to your left) coming from the cleaning pump and it will have an open end on it. This is the tube that delivers ink to the waste pad.
Use a piece of coat hanger wire or equivalent, and fish out this piece of tube. Bring it to the outside of the printer, thru the access panel.
Find yourself a suitable container (Tupperware or a plastic cup or jar) that is not too tall. Put the tube into this container and secure the tube and container so they won’t come apart or lose connection if the printer is moved.
If you wish you can make a hole or notch in the access panel cover so it can be replaced.
Anonymous
  • 541 Answers
  • Posted on Mar 24, 2009
SOURCE: red light is plinking
this mean that your printer waste pad is full and your printer needs to be reset go to this website http://www.ssclg.com/epsone.shtml
this will reset your printer
plz rate me
Anonymous
  • Posted on Apr 06, 2009
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Epson r300
check cartridge connector.
How do I change the ink cartridge on my Epson R300 photo printer
You can find the manual here:
http://files.support.epson.com/pdf/r300__/r300__u1.pdf
on page 90 - 91 there is a description how to replace the ink cartridges.
1helpful
After cleaning it and replacing numerous black cartridges, My epson stylus r300 printer won't print black ink. What should I do?
You could clean the black ink cartridge. For this you need to remove the black ink cartridge which is present in the printer. In order to clean the laser or scanner block you could use a cotton swab as it would fully clean the dirt. You need to clean the grime and the dried ink present in the printer. This would remove all the hindrances which prevent the ink from flowing. Cleaning the printer heads would also help to solve the problem.
10helpful
2answers
How do you change ink cartridgesfor the epson r300
Press Ink button;
Select Ink Cartridge Replacement
Press OK
changer cartridge
then press OK
And wait for initializing
1helpful
Changing the ink cartidge on Epson R300
The strip should have a yellow tab to pull on.. Check on the bottom of the cartidge and see if you can see a thin piece of plastic covering the pins. If not then the cartidge did not have the protective covering and could possibly have dried out.. Return it to the store and get a replaement.
Error with me epson r300
Hi-
when you go ro check ink levels- is it saying that there is a specific cartridge that you need to change? red light indicates no ink and all of the cartridges should have ink in it. try uninstalling cartridges and reinstall it and make sure you hear a click when you press it down. if that doesnt work,call epson 562-276-1300 for a complaint and replacement of ink. best i got!
thanks for using fixya!
Epson R300 printer leaking blue ink on rollers
Hi , clean both end of roller clean rug or cotton tip , this may happen during cleaning time some ink expose both end of roller sometime in piece of paper .during the cartridge in the middlle pullout the power cord stop cartridge and push cartidge down and lock.
Epson stylus photo r300 printer
those parts are not user-replaceable
call the vendor - check your warranty status
check this link just in case : http://www.epson.com/loyalty
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
