SOURCE: I HAVE A TORO SP
It sounds like the cable still needs more adjustment. The cable needs to be tighter. This is going to be hard to explain by typing. But I will give it a try. When you pull the handle in about 1/2 way mark the place where the lever on the drive motor is at. And take the cable loose and reattach the cable back to the mark that you made previously. So when the bar is released, it is like it is pulled in half way now. I hope that this makes sense. Let me know if I need to try to explain more.
SOURCE: My parents have a self
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
SOURCE: Toro Proline 400 blades fall out of engage
if your unit desengages have the clutch gap checked. also you should check for shorts in your safty wiring. the other would be a bad switch. finely your under warranty this my be warranted.take it to a toro dealer or call one to make sure
SOURCE: my toro mower disingages the blades after it runs for awhile
ik ben carolina beckers en ik heb met jaak coppens iets gaan drinken
