Look up to the upper right corner of the frige section and you will see a long white tube with a small latch on the end. Looks smaller than a Pringles can in diameter. Pop the latch down and the cover will lower. Hold the back as much you can and twist the filter about 1/4 turn counter clockwise and it should pop out. Once you install the new filter run a couple of "KoolAid" sized pitchers of water through the door to get all the air out of the line.
Here's the link to a diagram, it's item 15 http://www.partselect.com/ModelFrames.as...
Oh, and click on the diagram once to zoom in so you can read it better...
Perfect. Thanks!
