Brand new, appears to be no power going into charger.
SOURCE: what color should LED be when charged on duracell NIMH charger
When the batteries are charged fully the light should be green.
SOURCE: I fully charge the batteries with Duracell charger
Rechargeable batteries just don't last long in digital cameras unless it is a battery pack made specifically for the camera.
SOURCE: My 15 min. Duracell charger keeps blinking-won't work...
When the duracell lights blink during charging, AT YOUR OWN RISK, try a reverse charge. Instead charging positive to positive and negative to negative, try positive to negative and negative to positive. I did this for 2 minutes. This solved the problem. After the 2 minutes, I gave the batteries a normal charge. You will have to force the battery and charger contacts to touch.
SOURCE: Can I recharge Energizer 2500 mAh batteries with a Duracell AA/AAA NiMH Battery Charger?
Yes. The charger will charge any brand of NiMH batteries.
Testimonial: "Duracell said that their battery chargers were only for Duracell batteries. Also, I am understanding from your answer that a mAh battery is the same as a NiHM battery. Is that correct?"
