Threading the singer surger 241 and the tension on the 241
Check these sites
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 241) & click search
if they don't have what you need contact singer customer service
or
sewingpartsonline.com
sew4less.com
premiersewing.com
sewusa.com
mastersewusa.com
SOURCE: TS 380 Tiny Singer Serger Manual - Threading
If you go to this page:
http://www.singerco.com/accessories/manuals.html
at the search box, type in just the model number, ts380, and click search.
at the results screen you'll the "Free Download" for this manual (PDF format). (there are also options on that page to have them mail you one; but luckily this is one which also has a free downloadable version!)
Enjoy serging!
SOURCE: How do you thread the Singer QuantumLock 5 Differential Feed?
www.singerco.com/pdf/14SH654_threading.pdf
Its a different model, but most sergers thread the same way.
SOURCE: No tension on my Singer 6212C sewing machine
Take the thread completly off the machine and rethread it making sure it goes thru the tension wheel properly.
FYI Loops on the bottom-- Problem is in the threadding.. Loops on the top, problem is with the bobbin.
SOURCE: How do i set thread tension on a 306W Singer
Top tension about 4 or 5, make sure the presser foot is up when you theread the machine, make sure you can just pull the bobbin thread through with some slight resistence, if it is too tight slacken the screw on the bobbin case a quarter of a turn at a time anti clockwise.
SOURCE: singer 57817 thread tension problem
If you have Increased the upper thread tension on your machine, try these solutions.
* Decrease your bobbin tension if your sewing machine allows you to adjust it. Consult your manual.
* Re-thread your bobbin, It may be threaded incorrectly.
* Reinsert your bobbin, It may be inserted incorrectly.
* Change your thread. If your upper thread and bobbin threads are different types, try using the same thread for both.
I hope this helps.
