I can connect to net, but after a while connection just drops and I have to renew con. again on GUI. And that annoying guy on right keep saying ''You have set the wrong dynamic or static IP address for your RT-N10'' All setting are automatic!!!! note: yesterday i was given by provider a new wireless antenna because my old broke. any advice guys? help plz i'm getting desperate here.
SOURCE: No Internet access. Wep personal Connects to
1. You possibly may have the IP address statically assigned in the NIC card properties and or the router. ???
2. Go to the control panel then to network then check the properties of the TCP/IP procol properties to see if you have it set to "obtain an ip automatically"
also see if you have " DNS to obtain automaticall".
3.Unplug the ethernet cord for about 30 seconds the connect it back to the ethernet port.
4. check to see if you have a connection to the internect.
5. call your ISP to see if you line has had any disconnects or maintenance.
6. check the router status ( this will tell you if you have disconnected from the ISP 's server and need a possible reset .
7. Do a ipconfig /all to see if you have the "media disconnect" error > this is done by going to the command prompt and typing "cmd" enter then you DOS prompt will show.
8. check you status lights on the router to give this information to the tech when calling your ISP to walk you through a reset or check the connection on the DSL/ CABLE line.
I hope this helps. Have a great day!ormation to the tech when calling your ISP to walk you through a reset or check the connection on the DSL/ CABLE line.
SOURCE: my asus wl-500gP v2 can't connect to the wan
Your ISP address is dynamic, which means every time you log on to your ISP, your WAN IP address changes, this helps to stop hacking. Your ISP even though it is cable uses PPPoE/PPPoA, so you should set your router to this, not dymamic, setting your router to dynamic will make your router look for a different IP address every time your computer tries to log to it, your computer should have e.g 192.168.1.2, which is static, you can check this by going to command prompt and typing ipconfig, see what it brings up. hope this helps and post back if you need further help.
SOURCE: We have just bought an
Hi
You have to get the IP address of your internet service provide and once you type this IP address to the address bar. It will go you to menu set up of the router and set it up there. The encode the new password set up.
