I put the sa(sc)-pt660 together with a Samsung 550 series 1080p TV. Sound is great, but I noticed that very little of it was coming from the rear speakers. I see in the instruction manual that you can adjust the speakers individually +/- 6db, but I cannot seem to access the menus discussed on pgs 21 and 27. Anyone out there able to walk me through this.
Any advice is appreciated
SOURCE: Panasonic SC-Pt 660
I fixed the main problem. It has inputs, not labeled as such. one set right next to all the outputs labeled only aux.after plugging in to the TV outputs, and putting the unit on AUX, this was fixed. The surround speakers were harder to work out, After downloading the manual, I was able to get sound out of them, however at a lower level than all the others. Even following the speaker level adjustments in the manual, cant get more volume out of them...I'll keep trying.
SOURCE: problems connecting phillips tv to panasonic sc-pt660 home theate
I just bought a sc-pt660, I have a philips tv too, the TV only available output is digital coax but the home theater only has digital optical input, you may buy a digital coax to optical converter like this one:
http://www.amazon.com/Cables-Go-Coaxial-Optical-Converter/dp/B0002J2MV4/ref=pd_cp_e_3?pf_rd_p=413863501&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B000I98ZQY&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1BS8MKCZ1CWQR071S8RN
Alternativelly you can also use the headphone output that is near the side input in the TV and buy an RCA adapter like this one from radioshack: http://www.radioshack.com/product/index.jsp?productId=2103225
SOURCE: Adding another external device to the sound system
yes you are right you can pick up an arc aux swich box from radio shack.
will do your job just fine.
thanks
and pleas rate this, if is of help to you.
SOURCE: Panasonic SC-HT900-problems with surround sound mode and digital input
I have the same problem with my RCN system
SOURCE: blu ray connect to my sc-pt660
Why not leave the audio into the TV via HDMI from the Bluray and then optical audio out from TV to the home theater audio system? Same as the hook up for the cable box. The SC-
PT660 only has one optical audio connector so your solution may not be feasible assuming he's also got a cable box connected to the TV.
