Question about Maax Brio II One-Piece Neo-Angle Corner Shower with MAAX IES 1/2 System - 1
I have a maxx neo angle shower it is installed correctly and caulked correctly cannot get it to stop leaking at bottom corners
4 Suggested Answers
Anonymous
SOURCE:
  • 35 Answers
SOURCE: hi we just bought a maax breeze neo corner shower
There will be a nailing flange on the walls of your shower. Typically, drywall screws are used on this flange on the top portion and along outside edges spaced 6-8" apart. Use a high quality tub/shower caulk down the seams.
Posted on Nov 19, 2009
packrat1948
Paul Beyer
  • 528 Answers
SOURCE: The double roller assembly on
That part is Maax only, you will need to go through them or a dealer in your area.
http://www.maax.com/Corpo/DocumentsTechniquesCorpo.aspx
Posted on Mar 06, 2011
Richard Crate
  • 157 Answers
SOURCE: Trying to install a Maxx
Hello. You're not going to believe this, but MAXX says that the drain and the wall pannels (glued) will keep it in place if the floor is properly leveled before. Personally, when I installed mine (model 105525 - exactly the same installation instructions) I used silicone on the base at each stud area. it's secure, but not permanent, and won't allow an area for a crack to form.
Hope this helps.
Posted on Mar 26, 2011
Maax iris b leak in corner of fixed panel
Sometimes you have to override inadequate instructions with application of some common sense. It might be interesting to know why Maxx thinks the inside track should not be sealed. Also, test for water migration from where it should be to where it shouldn't be
Jul 13, 2013 | Home
I have a Maax Neo-Round Corner shower that leaks under the track the doors slide on. I have caulked inside & out but still leaks. Any suggestions????
You may have to remove the doors and the track and reinstall the track on top of a "bed" of caulk or sealant to prevent migration of moisture underneath. The leakage also may be caused by moisture running down the inside of the doors during active showering. Check also for warpage in the track that would cause it to seal unevenly
Nov 10, 2012 | 2003 GMC Envoy
Leaking Neo-Round shower stall???
Check really close to make sure there is not a small crack in the base. Many times they can barely be seen and when you stand in the shower they open up larger allowing water to leak out. You may have to have someone else stand inside while you look for the crack.
Nov 08, 2012 | Maax Acrylic Base for Shower - 102623
We have had our shower for 5 years now and it continues to leak at the bottom corners. we have the corner shower stall against a tile wall. I have replaced caulking several times even removing stiles...
You need the base taking out and installing properly.
If must be on a firm surface with no movement up, down, backwards or forwards. The best way is to glue it with a bed of expanded polystyrene so it can't move. Then you need a tile to shower edge filler which overlaps the base. Fill the gap with silicone, between the base and shower and when it is dry, put the edging piece on bedded into silicone. Then tile over the upper part of the edging.
Watch this video
Installing Shower Tray with Trimlux Shower Seal
shower tray edging Google Search
Nov 06, 2017 | Maax Brio II One-Piece Neo-Angle Corner...
Trying to install a Maxx Neo-angle corner shower with prefab plastic base. No description as to how to affix the base to wall (no holes or tabs to screw into the studs)... Only instruction is...
Hope this helps.
Dec 14, 2010 | Maax Acrylic Base for Shower - 102623
Tiled shower is leaking in one corner , installed 1 year ago
I don't really know the specifics. It sounds like you might need use some caulking on it.You can get it at a hardware store.
Mar 04, 2010 | Home
Hi we just bought a maax breeze neo corner shower how do i install the two back walls do you use glue or what?
Nov 19, 2009 | Maax Breeze: Two Piece Round Shower Module...
Bottom rail fit on 1500D door in 28" shower stall...
Mark, I'm having different problems with the same door. Try "filing" down the ends of the bottom rail, where it is contacting the curved corners. You might have to buy a metal file to accomplish this. Go heavy on the adhesive caulk on the underside of the bottom rail. Make sure the shower base is clean and dry. You might have to push down with your arms for several minutes to get the adhesive caulk to stick. Good luck, I have to go back to my folks this afternoon, because I can't get the door panel in w/o it scraping the top rail. Ugh.
Jan 22, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Maax Brio II One-Piece Neo-Angle Corner Shower with MAAX IES 1/2 System - 1 Logo
74 people viewed this question
Top Maax Plumbing Experts
Jay Saari
Jay Saari
Level 1 Expert
john h
Are you a Maax Plumbing Expert? Answer questions, earn points and help others
