Heating & Cooling Logo
Anonymous Posted on Apr 05, 2012
Want to turn off Auto-restart function of haier split ac
Hi. I have Haier split AC 2005 model, which has built in Auto-restart function after sudden power shut down. I want to turn off Auto-restart function, so that after power restoration,I manually turn it on by remote control. Please help
David Tickner
Level 2:
Sergeant:
  • Expert 159 Answers
  • Posted on Apr 27, 2017
David Tickner
Expert
Level 2:
Sergeant:
Answers
159
Questions
Helped
66776
Points
539
I do not know anything about this but from a manual I have seen its tied in with Timer and Sleep functions there are a lot of instruction manuals ou on the web but you description is to generic you need a model number of which there are a lot.
HSU-09LEK13/R2(DB)
HSU-12LEK13/R2(DB)
HSU-18LEK13/R2(DB)
HSU-24LEK13/R2(DB)
HSU-09LEK03/R2(DB)
HSU-12LEK03/R2(DB)
HSU-12CKAS(R2DB)
HSU-18CKAS(R2DB)
HSU-12HKAG(R2DB)
HSU-18HKAG(R2DB)
Just a sample look for a number on the device which may be under a cover.
As its software controlled they do need to reset themselves as to how long this takes varies from machine to machine.
Hope this helps
5 Related Answers
Anonymous
  • Posted on Apr 10, 2011
SOURCE: i lost my original haier remote control.how do i
NEED CODE FOR PROGRAMING UNIVERSAL REMOTE..(ANY COMMAND) FOR HAIER WINDOW AIR UNIT...D
bobotfel
Felizardo Erilla
  • 241 Answers
  • Posted on Dec 30, 2007
SOURCE: how to changetime in my a/c remote control
If you cannot see any buttons for time adjustment try looking for as small hole that fits the tip of the pencil. You can use pencil or pins to push the small button for time adjustment. After pushing the small button the time in the display will blink. Then you can now adjust the hour and minutes. And push again the small button to lock the time. Some button are find in the battery compartment of the remote control.
Anonymous
  • 86 Answers
  • Posted on Mar 17, 2008
SOURCE: I need a Remote plate for windows split ac
remote problem.replace remote
Anonymous
  • 9 Answers
  • Posted on Aug 21, 2008
SOURCE: I have a haier ac
Remove all power source and then restore power e1 should clear.
Anonymous
  • 81 Answers
  • Posted on Jul 20, 2009
SOURCE: LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Have floor portable Haier air conditioner (not window) model CPF12CLLB & need to know how to remove front cover
Haier offers window and portable AC units to fit your space and keep the temps ... Haier window air conditioner ultra quiet serenity model. ... Coming in at 43 dBA, it's the quietest window AC on the market*. ... Get AC When & Where You Need It ... excess moisture is removed from the air without you having to empty the unit.
For more click here
1helpful
Haier window AC leaking water.
yes its humidity with in the unit and fan is blowing it out [or condensation being blown around ] try lowering the fan speed
Why the AC flash stop and doesn't start, AC MODEL-CPR09XH7
Seems to be internal error its not working kindly its turn off the power supply and connect it again restart. Hope it will works
ZCF/LW-17-2 Remote Control AC-5620-36
Following amazon item link can be compatible for your Haier ZCF/LW-17-2
What's important is that it display in Fahrenheit.
Other ebay or amazon sellers sell replacement in Celsius
Amazon com Replacement for Haier HRRM Air Conditioner Remote Control Model...
SPLIT AC CONDENSER TRIPS AFTER 1 OR 2 MINS, ONLY DURING THE DAY TIME
The condensor is not cooling fast enough. Try cleaning the condensor coil. Also check that the fan goes on. At night the outside temperature is cooler and does not need much work to cool down the condensor.
I was just given a Haier air conditioner model HWR05XC7. It is not manual controlled. How do you operate it?
Unfortunately, the model number you listed is not a current Haier model. However, the electronic controlled unit, use a hand held remote control to operate and set the functions of the AC unit.
Call Haier America Customer Support 877-337-3639. As the may be able to help you and provide you with an Owners Manual.
Hope this helps you. Please let me know. Thanks.
I lost the remote to my ac how can I adjust the settings
you need a new remote. fortunately they are readily available
https://www.google.com/search?q=Haier+model+HWR05XC7+replacement+remote
RCECAOSHAN Replacement for Haier Air Conditioner ...
Amazon.ca https://www.amazon.ca > Replacement-Conditioner-00...
RCECAOSHAN Replacement for Haier Air Conditioner Remote Control 0010403473 Works for HWF05XCK-L HWF08XC5 HWR05XC5 HWR05XC6 HWR05XC7 HWR05XC9-L HWR05XCA ...
Controller type: ‎Button Control
Battery Type: ‎Lithium Rating: 4.6 · ‎341 reviews · ‎$21.97 · ‎In stock
  • Remote Control for HAIER HWR05XC7 HWR05XC9-L ...
    https://www.amazon.ca > HWR05XC7-HWR05XC9-L...
    Works as well as Original; No pairing or Code needed,Easy to control ,Hassle-Free Return; Battery type :CR2025,No batteries included; Looks better than the ...
    "); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 70px;"> Rating: 5 · ‎3 reviews · ‎$20.37 · ‎In stock
People also ask
What if I lost my Haier TV remote?"); display: inline-block; height: 24px; width: 24px;"> Can we operate Haier AC without remote?"); display: inline-block; height: 24px; width: 24px;"> Can you replace an air conditioner remote?"); display: inline-block; height: 24px; width: 24px;"> What is the price of Haier remote control?"); display: inline-block; height: 24px; width: 24px;"> Feedback
HAIER HWR05XC7 Replacement Remote Control
Remotes.net https://www.remotes.net > products > replacement-rem...
The RTAC562030 is a custom-built replacement remote control to the original HAIER HWR05XC7. It will perform all the functions that the original HAIER remote ...
US$34.90
HQRP Remote Control Compatible with Haier HWF08XC5, ...
Walmart https://www.walmart.com > ... > All Remote Controls
HQRP Remote Control Compatible with Haier HWF08XC5, HWR05XC5, HWR05XC7, ... TCL Roku Replacement RC280 Ultra Remote Control with Netflix Sling Hulu Vudu Key ...
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 42px;"> Rating: 3 · ‎2 reviews · ‎US$12.95 · ‎In stock
Replacement remote for Haier HWF08XC5 HWR05XC5 ...
eBay https://www.ebay.com > ... > Remote Controls
Find many great new & used options and get the best deals for Replacement remote for Haier HWF08XC5 HWR05XC5 HWR05XC7 HWR05XC9 HWR05XC9-L at the best online ...
US$16.00..
Top Heating & Cooling Experts
Paul Carew
john h
