Ricoh Aficio 1035 Copier Logo
A
Anonymous Posted on Apr 05, 2012
Richo error code sc 829
Please solve my problem
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 01, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1816
Points
I have Aficio MPC 2550 and it displays Sc 829. Is the a way to reset this code?
5 Related Answers
joel_baleta
Joel Baleta
  • 155 Answers
  • Posted on Jan 24, 2010
SOURCE: What is meant by error code SC 403 of RICHO AFICIO
SC 403 is a Transfer belt position sensor error
The transfer belt position sensor does
not activate even if the transfer belt
contact clutch has been switched on
twice and rotated once. Pls check if
Main motor/drive, Transfer belt contact clutch if defective, Transfer belt position sensor
if defective. or your Photo sonductor drum/PCU carriage unit does not turn or stock up or not inserted properly.
walesarumi
Wale Sarumi KomputerSolution
  • 6993 Answers
  • Posted on Oct 09, 2010
SOURCE: sc:829 code:301 detail:A4000001
there is something wrong in that machine this making it display this error code. The error code has a meaning and this meaning needs to be interpreted first, before the problem can be identified.
The error code means; charge Corona problem. The charge Corona of your machine is defective and that's what causing the problem. The charge corona is a power pack and it is located inside the drum of the machine.
To be frank, you will need
a technician to help you service the machine in other to get it fixed.
Good luck.
Anonymous
  • Posted on Jan 06, 2009
SOURCE: error
problem ricoh photocopier model no. 2015 error sc 552
Anonymous
  • Posted on Oct 27, 2008
SOURCE: Error code sc 500
check the developer gear...txt me at 09275514418
faatmaan
  • 6 Answers
  • Posted on Feb 15, 2008
SOURCE: error code sc 422
422 D PCC leak
- Timing & Condition -
When the current leak is detected
for 2 seconds, leak detection
starts 1 second after the PCC
turns on. The leak signal is
monitored twice at 1-second
intervals. When the leak condition
is detected twice continuously,
this SC is displayed.
1. Check if the PCC unit is properly installed.
2. Replace the corona wire if it is broken.
3. Check if the connectors on the terminal and
high voltage supply board (T1, PCC)
are
properly connected and if the cables are
damaged.
4. Clean the receptacle.
5. Replace the high voltage supply board (T1,
PCC)
6. Replace the I/O control board.
7. Replace the main control board.
- Signals to Check -
[A258/A259/A260]
Leak Detection:
CN227-B1 on I/O control
Board
[B017/B018]
Leak Detection:
CN221-B1 on I/O control
3answers
Ricoh Aficio SP C232S. How to solve Error Code SC 829 on Ricoh 232-0 please?
Question edited for clarity and correct order, 'make model problem'.
Error Codes > Ricoh > AP828 > Code SC829
PrintCopy .info https://printcopy.info > brand=Ricoh > code=SC829
Ricoh AP828 · Code: SC829 · Description: Self-diagnosis error: optional RAM [XXXX]: Detailed error code [0302] Composition error (Slot 0) The result of checking ...
Missing: 232 ‎' Must include: 232
How can i fix the error code sc 829 code 0401 in ricoh mp 4500
you can see this link:
https://www.youtube.com/watch?v=CVwwMtZZgOs
How can I clear error sc 20000 0n richo ipsio sg 7100 printer
WHEN i PUT PRINTER ON RED ALERT LIGHT ON ERROR sc 20000 WHAT CAN i DO
Sc 440 in richo afichio mp 9000
hellow my mp 9000 send massage as SC 180 what does it mean and how can i solve it, need rapide help please.
2answers
Error code sc 500
Main motor lock error
Failed to detect main motor lock signal for 7 checks in succession (total of 700ms) after main motor started to rotate, or after last lock signal was detected.
Main motor defective
Too much load on the drive mechanism
Motor driver damaged
11helpful
2answers
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
1helpful
3answers
Error
I do not recognize either of these codes (187 or 387) as part of the Aficio 2015 error list.
If the code is displayed on the screen, physically TURN OFF the copier with the main switch (red switch), wait 10 seconds and turn it back on. If it's an erroneous error, this should reset the error code. NOTE: THE ERROR CODE MUST BE DISPLAYED FOR THIS TO WORK.
Top Ricoh Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
