New machine is inoperable at the moment (DARK SCREEN) Often it was slow when responding to commands or may not respond at all... Example opening up folders, files... Anything... Problem seems worse today. The client rebooted and there's a black screen Troubleshooting - The Client rebooted a few times and the screen remains black. No errors messages. - Removed & reconnected the battery. Same issue
SOURCE: screen is black; cannot get anything to display
Turn it off, take out the power supply and battery. Now open it and take out the button battery. With those things out, press and hold the power button for 10 seconds to drain residual charge. try to boot it up. It should work now
SOURCE: how to unlock touch pad
i thinks every laptop has a touchpad icon i the lower right of the taskbar, try to find it and right click it to see if it's lock, i hope this information will help you solved your problem, let me know if it works. : )
SOURCE: New laptop updated 12,000 some files then gave the
Hi
The operating system might be corrupted or the hard disk drive is damage and needs replacement.
SOURCE: G42-415DX laptop - will not
Make the FixYa experience better for everyone by voting.
My name is Ben and I'm your guru, i.e., mentor, an influential teacher or popular expert: a management guru. - origin from Sanskrit, 'weighty, grave', for today.
I suggest that you click on the following link to retrieve the HP G42-415DX maintenance and technical manual: Free Maintenance Download
All the best
Ben
