SOURCE: delta faucet 470-ss-dst is leaking from the spout.
easy fix, shut-off water at under-counter angle valves and water meter, pop-out the blue and red insert located on the front of the handle of the faucet, turn faucet on to relieve pressure, loosen allen screw under red and blue insert, pull handle up, remove nut under handle, remove plastic insert gasket and stem under the nut, notice two rubber gaskets.... remove them and the springs behind them and replace, when putting the insides of the faucet back in pay close attention to the notches and grooves,,,, the parts only go back one way....
SOURCE: My Faucet started dripping. I have installed two
Be sure you have the right kit for your faucet. I think there are two types of springs. I usually leave the ball adjustment loose, and tighten the cap. Then I use that little spanner wrench to tighten the ball. Have you used the little wrench to tighten?
SOURCE: I have a two-handle Delta faucet that drips
sounds like you need to replace the valve seats. if you shut the water off and remove the handles you will see the valves. you have to remove them and under that you should see these little black things. they come out but have springs under them so be careful. the black things are the valve seats. i would start by replacing them
SOURCE: Delta Faucet Kitchen Single Pull
Yes, It can be fixed but it isn't a washer. There is a replacement stem for the faucet . They are readily available at most big box stores and possibly the local hardware store. Bring your faucet model number with you.
Phil
SOURCE: Delta single handle kitchen sink faucet
Tuen the stops off unsder the sink . Remove the alaen screw from the handle. Using a spanner wrinch or a needle nosed pliers spred apart unscrew the large nut that has two slots. Lift the whole assembly out. Take assembly to the plunmbign supply and match ius the kit that youy need with has two new rubber seals and two springs and maybe a new spanner nut. It also comes with the spanner wrench and allen wrench needed to renstall. Tip you may be able just to tighten the spanner nut(clockwise) and stop the leak w/o rebuilding it.
Those faucets are made by different companies and they put their name on them. Delta Price Pfister most likely. Sorry but you will need to pull it apart and see which it is. That is a hardware brand faucet and may be made by any of the major brands.
