SOURCE: Maytag Neptune stops during rinse cycles
I think the cold side of your water valve is stopped up at the screen. Just take your hose off at the machine and get the crud off the screen in the valve. It only does it in rinse because you have cold rinses. When warm water comes in, it will fill just fine because the hot water is not blocked
Could yoy please explain what the "screen" is?
Thanks,
Carl.
SOURCE: Washer leaking when filling up tub
Unlikely to be pump, sounds more like hose leaking, or drum seal.
Depending upon severity of leak, place a sheet of newspaper under front of m/c, pushing it as far back as you can. switch m/c on for a few secs, then switch off, remove paper and you should be able to judge where leak is.
Tilt m/c back and have a look underneath.
At 12 years old, if it looks major, I think I would replace m/c.
Plz rate my solution.
Thanks.
i dont know what he is talking about and the leak on that machine I am 99% sure you just need a new pump it leaks out the center of the pump where it goes on the motor shaft just lean it back take off the 2 clamps on the pump slide it off the motor and then take your hoses off it then just reverse it with a new pump
SOURCE: Maytag Atlantis MAV6200AWW Washer Problem?
is your drain hose at the top of the washer .is the water just runing out is it being pump out
