I'm trying to change the security settings on my new wireless router. How do I change the password?
You need to access the router's GUI page to change the security key of the routers/
remember, once you change the security key, it should be changed in all the devices you got connected wireless.
you can access the GUI page by typing either 192.168.0.1 or 192.168.1.1 (most of the routers have this default setting) in address bar of internet explorer.
you can find the exact numbers by going to start>run>type "cmd">type "ipconfig">enter
you will see the default gateway number which is the one you need to type in a address bar of the internet explorer. (these steps work only if you get the computer connected with the Ethernet cable first to the router)
once you access the gui page, you have an option to change the wireless key under wireless section>security.
need to mention that when you access the GUI page, you will be welcomed by a username and password log in option. the default username and password again is admin in most cases. if it doesn't work ,check with the manual of the router you got.
if you still need more clarifications or steps on this, please reply to the post.
SOURCE: Cannot Set Password on DI524 Wireless Router
Alright, it was a dumb thing to do....just make sure you use internet explorer...It works in there...don't ask why lol....I have no idea :D
SOURCE: Dell Wireless 2350 Router
Connect one of the router's LAN ports to the computer, no other connections to the router.
Reset the router to factory defaults by holding the reset for 15 seconds with power on.
Reboot the computer.
Start, Run, cmd /k ipconfig
The address of the Default Gateway is the base address of the router, type that into IE to access the setup pages.
SOURCE: ZyXEL P-660HW-D3 password change
There should be a tiny recessed 'button' (usually more of a hole) in the back of your router. This may be marked 'reset'.
To use this to reset your router, the manual for the Zyxel P660HW router advises that your power LED should be on, but not blinking.
Push the end of an opened out paperclip into the 'reset' button (hole) for 10 seconds, or until the power LED blinks. This restores your defaults. The manual I have advises that your password will be reset to 1234. If you have a manual, please check this.
Good luck ;-)
SOURCE: Cannot Set Password for Security on Edimax Wireless Router
Try to download the manual from here:
http://www.edimax.com/en/produce_detail.php?pl1_id=3&pl2_id=18&pl3_id=43&pd_id=261
and just have a good read?
Merry Xmas
A
wireless network is comprised of a wireless router, a computer (or
other wireless-enabled devices), a high-speed modem, and a subscription
to an Internet Service Provider (ISP). Netgear is a popular
manufacturer of wireless networking hardware that allows users to set
up a secured wireless network. In order to prevent unauthorized users
from logging onto your wireless network to gain access the Internet,
and in order to protect the data you transmit and receive online, you
should change your wireless router's security settings to create a
1 Install the router. To install a Netgear wireless router, use an Ethernet cable to connect the router to the cable/DSL modem and use another Ethernet cable to connect the router to your computer. Make sure all of these devices are powered off as you connect them. Once connected, turn on the cable/DSL modem, the router, then the computer, in that order. Allow at least two minutes to pass after turning on each device to give the devices time to recognize one another
2 Log in to the router. Open a web browser and type in the router's address to load the router's settings page. The router's address can be found in the user guide or setup CD that came with your router, or you can download a user guide from Netgear's technical support page (see Resources). Most Netgear routers use one of the following addresses: http://192.168.1.1; http://www.routerlogin.net; or http://www.routerlogin.com. Press "Enter" or click "Go" in your web browser after you have entered the address.
3 Enter the router's username and password. A prompt will appear on the screen when you enter your router's address, requiring you to enter a username and password before you can access the router's settings page. The default username for Netgear routers is "username" and the password is "password." Because the textboxes are case-sensitive, you must enter both of these using all lowercase letters. Press "Enter" to log in to the router and begin changing its security settings.
4 Open the security settings menu. The router's home page has multiple links for changing settings. Find and click the "Security Settings" link to change the router's security settings.
5 Change the SSID, choose an encryption setting and create a password. The default name (or "SSID") of your wireless network will be "NETGEAR." Enter a new, memorable name for your wireless network to help detract would-be hackers from trying to access your router, as most novice computer users with unsecure networks do not know how to change the default network name or institute any other security features. Newer Netgear routers offer WPA or WPA-PSK encryption to secure your network, both of which provide high levels of security. Select either of these. encryption types and create a unique password. This will require all users to enter the password before they can log in to your wireless network. It is important that you create a complex password that has several characters, including numbers. Once you have created a password, click "Confirm Password" to save it. To exit the security settings menu and log off of the router, click "Save" or "Apply" to save the changes you made, then click "Logout" to exit the route
Things You'll Need
* Netgear wireless router
* High-speed Internet service provider (e.g., Comcast, AT&T, Insight)
* Cable/DSL modem
* 2 Ethernet cables
* Computer
* Web browser
* Router address
* Router's username and password
Good Luck : ) ....
