We have had this dishwasher just 2 weeks. Today we notice many tiny brown spots inside, on the bottom part of the door and on the interior base, on the stainless finish. Difficult to clean off, but will eventually come off with a paste of dishwasher powder. What could be causing this?
Hello -
The cause of the stains on the interior of your dishwasher may be the water. Do you know if you have hard water, water with a high mineral content? If so, do you know if the water has a high iron or maganese content?
If you have hard water in your home water supply and do not have a water softener, check the owner's manual for your dishwasher - the Troubleshooting section - to see if there is mention of stains on the interior of the dishwasher.
From the American Cleaning Institute web page on Automatic Dishwashers:
http://www.cleaninginstitute.org/clean_living/automatic_dishwashing_problems.aspx#Yellow
Yellow / Brown Stains
Causes:
Iron or manganese content in water supply.
Solutions:
After food soil is removed, wash dishes with citric acid crystals. Check dishwasher manufacturer's instructions for amount to use and method. Do not add detergent.
A liquid product is available to remove iron deposits from the dishwasher interior; follow the package instructions.
To retard staining, use maximum amount of dishwasher detergent to keep iron or manganese in suspension during the wash. Use a rinse additive during the rinse.
Preventative Measures:
If staining cannot be controlled, the only solution is in the installation of iron removal equipment in the home water supply.
Some solutions to the interior staining problem recommend the addition of citric acid crytals to the covered section of the dishwasher detergent dispenser. If you do that, be sure you do not have any sterling silver or silver plate tableware in the dishwasher. (Those items are best washed by hand, anyway.) Citric acid will cause pits on sterling silver and silver plate. Note: Some dishwasher detergents and dish liquids have citric acid in their formulations - check the ingredients.
Best wishes.
SOURCE: Brown sticky spots
sounds like you have an oil leak from the motor/pump assembly. this should be covered under warranty by the mfg. have a technician replace the sump assembly.
SOURCE: Kitchenaid Dishwasher Latch Broken
GET A FLAT HEAD SCREWDRIVER TRY TO PUSH THE LATCH TO OPEN THE DOOR...
SOURCE: KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
SOURCE: Kitchenaid dishwasher leaking from door
Check the screws on the pump cover under the lower spray arm (the spray arm is easy to remove, the screws are torx - maybe a torx 10 or 15, so a regular screwdriver wont work). They come loose on ours every 6-12 months and spray water at the door, causing it to leak all over our wood floor. I routinely tighten those screws now before they come loose enough to cause the problem.
SOURCE: KITCHENAID DISHWASHER DOOR PANEL
www.applianceart.com has many options for you to choose from. They sell many different panels to put on your dishwasher. If you call them (678-727-4747 x32) they can also send you a metal stainless plate that is easily installed. I think the metal ones are around $99.99 and the other options are $39.99
