Hello,At the begginning the problem didn't even exist.The Hi-fi was working fine until one day that my display screen was "off".I can't see what station or song it is playing but if I light up a bit the screen,with a light ,I can barely see the name of the station or the song.So i suppose it has to do something with the brighness. Thanks in advance
SOURCE: motorzor
you simply fried your battery by overcharging it. Just get a new one, let it fully charge and fully die twice before you start normal charging. Then you will want to only charge it for about 2 to 3 hours or find a charger that has a smart chip that tells it when to stop charging once the battery is full.
SOURCE: Change LCD display screen on Nokia 6288
U need the precision tools to fix it ... do u have it ???
SOURCE: outside display screen will not show anything but the motorolla logo
the solution did not help
even if i tried it
the external display still displays the motorola logo even when it's close or open
SOURCE: display screen says "invalid battery" All works fine, what does that mean?
your battery may be putting off an incorrect amount of voltage to the phone, and powering it on (yes) but frying it internally (no!)
Meaning, the battery may make it work, but it is not good for the phone.
NGK
SOURCE: Phone display is very dim-can barely read
Well, first you will have to check your options, if you can read it enough to get in there. You may have the backlight turned off. If the backlight is not turned off, then you probably have a bad backlight and will have to take it to your provider to get it fixed. Replacing a screen/backlight is not something I would attempt to do unless you are certain you know exactly what you are doing as you can render the phone completely useless.
