Electronics - Others Logo
A
Anonymous Posted on Mar 28, 2012
Husky jump-start ac/dc adapter to charge Husky jump-start 400 amp
I just need the Ac adapter to charge Husky jump start 400 amp
Mike
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 01, 2014
Mike
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2219
Points
9
Sure, you can find it on amazon... here: Amazon com Husky jump start adapter . I hope I have helped. Cheers
5 Related Answers
Anonymous
  • Posted on Nov 11, 2009
SOURCE: I need to know the AC/CD adapter part number for
5140045-42 AC Charger with Small Jack 12v 500ma 2.5*5.5mm. For units Manufactured with date codes before October 2006.
Anonymous
  • 52 Answers
  • Posted on Jan 11, 2009
SOURCE: I need to replace the 120 volt AC wall adaptor
Here is your link to buy it.
http://www.centurytool.net/5140044_04_Charger_W_Small_Jack_p/5140044-04.htm
Anonymous
  • 323 Answers
  • Posted on Nov 06, 2009
SOURCE: Lost AC charger and lighter adapter - need replacements
Although the MotoMasters are quite popular and are excellent products in most folk's opinions, parts are quite difficult to find. Complete units are in abundance.
Your charger doesn't have to be branded MotoMaster. And charger of approximately 500 to 750 mA and approximately 14 volts will work nicely.
From time to time Canadian Tire have some parts or open box sales. You might check with them. Hope this helps!
Sirwriter
Anonymous
  • 12 Answers
  • Posted on Nov 20, 2009
SOURCE: I have lost my ac charger for my VEC013DB 400 amp
You can find that part on Dewalt - Black & Decker website - they make 2 different A/C chargers for that model.
This is the link to their website: http://www.dewaltservicenet.com/Products/ProductDetails.aspx?pid=68905&tid=15684
This is the part number for the 12v - 500ma AC charger: 5140045-42
This is the part number for the 12v - AC charger with the barrel pin: 5140045-34
They run about $14. on their site.
Anonymous
  • 843 Answers
  • Posted on Feb 23, 2010
SOURCE: 200/400 watt Powerline Dc to AC Inverter blows fuses
If the inverter is blowing the fuse immediately upon plugging in the inverter (before you even plug something into the inverter) you most likely have a short in the 12V power cord. If you have an Ohm meter, you should be able to check the resistance across the two contacts on the 12V plug of the power cord. Wiggle it around some. If you get a very low reading, and especially if it's intermittent, you have a bad cord, which should be pretty easy and cheap to replace. My experience with these cords has been that their quality is pretty poor.
If that is the problem, maybe you can cannibalize a cord from an old CB radio, but here's a fairly heavy duty one on Amazon (they don't give an amp rating though) http://www.amazon.com/Truckspec-TSPSCBH-2CP-12-Volt-Platinum-Replacement/dp/B001JT5QF0
Testimonial: "Al, the idea on the Powerline appears to be the correct solution. The R was very low as you predicted. I'll change out the powercord. Thanks !"
A power on board veco12pob 450 amp jump starter please: What is minimum amps to charge? How test jump pack ?
You should need 12V of DC Voltage at about 5mA which is equivalent to .5 Amp or 1/2Amp. 1000mA(milliamps) is Equivalent to 1 Amp. See the included pics- one is of my Charging Unit for a Nearly Identical Jumper Box. Hopefully this helps.
You can use a AC/DC adapter as pictured and it's ok to use one with a higher amp output, but you can't use one with a lower amp output or it simply won't charge.
Need AC power cord for task force model 202754 tire inflator
This a battery jump pack that is used to jump start a car. Some units have an ac adapter built in so you can charge the battery in the jump start pack. My unit has a spot to connect the ac adapter to the jump pack so you can charge the battery in the jump pack. My ac adapter has been lost. I know I have to buy a new ac adapter so I can charge my jump pack, what I do not know is if the input (from the ac adapter) is 120v 60 hz
I understand that the DC output needs to dc12v. I do not understand the milliamps. The battery in the jump box is 12v 10 ah ( what ever that is). I just want a new ac adapter to charge the jump pack with that is not going to damage anything.
2answers
Veco 11 300 amp jump start system power supply
recharges from standard AC
Use an w\extension cord
Lost my charger need to charge from internet
Laptop chargers also be called as power adapter, AC adapter or DC adapterCheap Laptop Charger online for UK For US: laptop AC adapter & laptop DC adapter You can use universal laptop AC adapter too.
49helpful
2answers
Vec010bd AC charger part # 5140045-34 question . . .
barrel pin 12v 500Ma is correct. the only other required stat that you need to know is that the polarity is( ---------that's how the inside pin polarity is shown on the transformer. Go to any radio Shack, and they have this charger in stock. tell them you need a 120v. a/c input, 12v. DC 500 ma output, with the center (inside) pin positive( ).It should be less than $20.00
24helpful
4answers
Instructions on AC Chargeing Vector Jump Start 12 volt
When charging the jump starter , should the switch be on or off .
Top Black & Decker Electronics - Others Experts
ADMIN Andrew
ADMIN Andrew
David Kassin
David Kassin
Are you a Black & Decker Electronics - Other Expert? Answer questions, earn points and help others
