Samsung RF265AA Bottom Freezer French Door Refrigerator Logo
Anonymous Posted on Mar 27, 2012
Freon leak in refrigerator?
Bad odor developed in fridge last couple days, even ice tastes bad, almost a chemicle smell, could it be a freon leak? Frige is only 3 years old and cooling fine.
  • Anonymous Mar 23, 2014
    my fridge has a bad odor
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Mar 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
6110
Points
42
No refrigerant leaks have little to no odor and if it was leaking bad enough to smell it the unit would be out of refrigerant and not cooling...the problem sounds like gases coming off of a veggie of something un-covered inside the fridge--have you put any veggies in the fridge or freezer un-covered check real good if one or a piece of something has fallen behind something else where you cannot see...all else fails remove all your products from the unit and clean and get a box of odor control arm&hammer to rid the smell..as for a leak in the sealed system i think your just fine.
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Aug 24, 2008
SOURCE: Samsung RS2545SH coils freezing
Hey how's it going? I may have the info you need, but first I need you to go through a check list to see if there is a simple fix.
Check to see if there are any obstructions in the freezer drain (freezer drain located inside freezer compartment behind back panel lower right hand corner of the freezer coils) if there are obstructions or debris remove and clean with a mild dish washing detergent and water, check to see that water can drain freely. see if this helps.when the coils freeze is the ice flaky or is it frozen solid ice? if the ice is flaky it could mean that either the refridges/freezer door are left open to long "check your door gaskets or seals by closing the on a dollar bill if it pulls out easily with little to know resistance your door gaskets may need to be replaced. After you defrost the freezer coils did you notice if there was water in the condensor pan, if so good sign. (condensor pan: is the pan that collects the water that drips through the drain hole of the freezer compartment caused by the heating of the coil by the coil heater: water that enters the pan collects and is reused by the condensor fan by blowing warm air partly into the water and through the condensor coils causing them to cool.)if you still need to test your bi-metal therostat or your glass heater/ice pipe heater, you will need a multimeter and knowledge on the use of it.(IF YOU 'RE NOT NOT COMFORTABLE AROUND ELECTRONICS AND ELECTRICITY PLEASE CONTACT A QUALIFIED REPAIR SERVICE AND REMEMBER TO UNPLUG APPLIANCE BEFORE ATTEMPTING ANY REPAIRS) for more info on how to test please reply,Good Luck, be safe..
Anonymous
  • Posted on Apr 01, 2008
SOURCE: freezer temp too high
Air must circulate in the freezer when working properly. I am guessing the recirculating vent in the freezer may be blocked which would not bring warmer air back to the coil to be cooled. As for the door, I theorize there may be too much negative pressure which pulls the door in while you were pulling out ... don't have solution yet.
Anonymous
  • 149 Answers
  • Posted on May 09, 2008
SOURCE: fridge not cooling
check the following is freezer fan running? if so that's o.k.
if you handy with a voltmeter put it on the "beeping feature" disconnect power from fridge then disconnect the two wires from the defrost heater put one lead from the meter on one side then put the other lead on the other side if it beeps its good if it doesn't bad defrost element replace it and replace the defrost thermostat
Anonymous
  • 212 Answers
  • Posted on Jun 24, 2009
SOURCE: Refrigerator Side Not cooling
you right but your problem lies in the defrost cycle. your units defrost timer, defrost thermostat or defrost heater has failed. defrost thermostat and heater are located on the evaporator. both can be ohmed out. when the ice builds up on the evap. your cold air can not be transfered to the fresh food side. make sure the fan on the evaporator is running
Anonymous
  • 3 Answers
  • Posted on Feb 03, 2011
SOURCE: We have a strong "plastic"
try washing with vinegar solution. it is just the new factory smell and taste.
My Frigidaire has a bad odor in the freezer and the air blowing into the fridge...the ice tastes bad as well but the water is okay? Help
Sounds like you need the water lines and the ice maker housing cleaned as much as possible. Contact a professional for the best way to do this.
2answers
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Chemical smell in frig permeating food taste. Is it dangerous
First remove all the food and produce and thoroughly clean the fridge with disinfecting wipes, then put a couple of boxes of Arm And Hammer Baking soda in the fridge to absorb the odors. And no it is not dangerous in my opinion. I have smelled fridge odors that would gag a maget
2answers
Refrigerator and freezer musty, freezer burned smell? ?
they should be washed every2 months use baking soda and a box of fridge charcoal
thumbs up
67helpful
8answers
Ice and Refrigerator and Freezer smell like alcohol chemical
I believe that you might have a coolant leak causing the chemical odor. You really should get it checked out by a fridge repair-person because it's not healthy to breathe in the fumes.
Top Samsung Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
