SOURCE: received E6 and F2 code. repair man replaced the
Hello & Welcome to FixYa
F2-E6 error code indicates an open/shorted oven temperature sensor and to solve this problem the temp.sensor needs replacement. If you want to be sure then before replacing the sensor you can test it with a voltmeter for around 1100ohms....if it reads more then 1120 ohms then it needs replacement however, if the reading is between 1080-1120 ohms then it is the control board that needs replacement. However, after reading your problem it seems that the sensor is causing this and replacing it is recommended repair. Please get back to me if you have any other questions.
Kevin
SOURCE: Displays F2 E6 on Whirlpool RBD305PDQ10 double
I wrote a blog on this topic recently, perhaps this will help you:
appliancejunk.com/blog/2009/11/11/whirlpool-oven-e6-f2-error-code-failure-andor-blank-display-board-not-available/
Best Regards,
Bruce
www.fixyourboard.com
SOURCE: I have a Whirlpool double oven (model
An E6 F2 error code on these parts has always been due to the control board. These controllers can be repaired quickly and reliably at www.fixyourboard.com If buttons are not working or you get an F2-E0 or F2-E1 then it is the keypad
