Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore Elite ice maker no longer opens flap to dispense ice
A few weeks ago the in door ice maker light started flashing and it sounded like a relay was clicking on and off. This would go on for 20-30 minutes then stop and all would be well. We also noticed that the ice dispensing flap was open allowing cold air to escape. We eventually figured out the if you engaged the child lock it would stop. Now the flashing and clunking has stopped but the flap that allows ice to fall into your cup no longer opens when you push the dispens lever. Other wise everything works. You can reach up and open the flap with your fingers and the ice that has been brought forward by the auger will fall into your hans. Basically the flap doesn't work. Help!
Mod # 795.77562600
Are there any trouble shooting or service manuals available?
Thanks
Anonymous
SOURCE:
Anonymous
  • 146 Answers
SOURCE: ice maker failure
1) Check the filler tube which allows water to enter the dispenser through the back wall of the freezer. This tube may be frozen inside. You can pull the tube out gently and clear it.
2) The inlet valve may be faulty/blocked. Where the water connects to the water valves behind the fridge, try to swap the plugs around from the one valve to the other. They should be colour coded. Then try dispensing water. If water runs into the ice-maker then the ice maker valve is faulty/blocked.
Posted on Oct 30, 2007
Anonymous
  • 8 Answers
SOURCE: Kenmore side by side
take out ice bin, make sure you get it lined up when put back together, should click,sometimes they are a little off and you have to keep trying, mine has that defect, it works, but only on its terms, its a pain to do, but that can stop it from working due to a safety thing
Posted on Nov 08, 2007
larryyb
Larry Youngblood
  • 291 Answers
SOURCE: Ice maker in a Kenmore Elite Side by side refrigerator
check the head of the icemaker and see if the gear is broken on the module
Posted on Nov 26, 2008
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: The ice maker works, but does not dispense
The bar, hinges or sensor may be broke or shot..
Posted on Jul 08, 2009
ImJustAvg
  • 2006 Answers
SOURCE: I have a Knmore side by side fridge, model
One is the icemaker will leak on the auger motor and freeze it up as you describe. If this is the problem the ice will be very solid (hard ice). If this is the case check to see if the tube that feeds the icemaker water is clogged with ice and if so remove the ice and replace the water valve. If not the icemaker may be overflowing, which is still most likely due to a bad water valve.
The other thing that will cause this is an air leak. If it is an air leak the ice will be frosty more like snow than hard ice. But even so it will still cause the auger not to work. If this is the case check the little flap that opens and closes to let ice through the door to see if it is closing properly. Then check the door gasket to see if it is sealing properly.
Turning the temp. down shouldn't help nor hurt your problem.
Posted on Jun 08, 2011
I have a Kenmore Elite side-by-side refrigerator with ice and water in the door, Model No. 106.58963701. The ice flap is staying open and letting warm air into the freezer and freezing up the ice maker...
Here is a large diagram and a PDF of the parts. Most likely you have a broken door flap spring broken or the hinge. Click Here=> 8201649 Dispenser Door Flap Kit
Click Here=> W10224328 Spring Here s a PDF of all parts related to your models dispenser=>
KENMORE_106.58963701_REFRIGERATOR_SIDE_x_SIDE_Dispenser_Components
Click here for=> 106.58963701 Dispenser Components
If you need instructions on how to take the dispenser apart please let me know. You really will not see the true problem until you have the dispenser disassembled. Hope this has helped answer your questions, Thanks, Sea Breeze
May 04, 2011 | Refrigerators
The ice maker on my Kenmore refrigerator freezes up when it despenses ice. I've defrosted it several times, but within a few days the dispenser is frozen up again. I think the flap that dispenses the ice...
Maybe the "spring" system of the dispenser lever is faulty, try open it and closing with your hand and see if it will stay close on its own.
But yes you are right, it freezes because warmer air is entering though the dispenser
Jan 10, 2018 | Refrigerators
Alarm no longer sounds when fridge door is open
Chances are that you will have to replace the buzzer. That part is available at Sears Direct. J
May 28, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite refrigerator ice and water dispensers not working
check for a child lockout button it will look like a tiny padlock ,press and hold for 3 sec.(could be the freezer door light switch)
Jul 24, 2009 | Refrigerators
Icemaker - flap won't open, cubes collect in chute
the actuating paddle that you are depressing to dispense ice actually pushes the door open at the top of the dispensor, soundsas if thered an issue withthe actuator arm
Nov 18, 2008 | Frigidaire FRS26R4A Side by Side...
Kenmore Elite refrigerator Model 596.76533500 temperature control panel locked?
I have this problem also my control panel is not working. It has an Er If on the panel.
Oct 08, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Oct 30, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
No ice through dispenser
When you operate the ice dispenser lever, you should be able to hear a little click from a micro-switch that then switches the auger motor and the light on and also opens the flap. If you cannot hear this small click, then the micro-switch is faulty. The ice dispenser only works when the freezer door is closed, so you could also inspect the door light/fan switch for proper operation.
Oct 30, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Ice maker failure
Oct 23, 2007 | Kenmore 50522 / 50524 Side by Side...
Ice maker repair and still no ice
Amyc, of course you should call this cat back, but here are a few things to check. Make sure that the fill tube is not frozen over. The black tube feeding water to the IM. Next with the freezer door open your optics should flash twice with a pause repeatedly. Hold the left side emitter flap down and the light should be on steady. If this checks, the optics are good. The ice maker rakes should be at the 2:00 position when it's in it's home positon. Any other position could be a bad module. When the cat comes back to check it out, make sure he jumps the ice-maker to get the unit to fill before he leaves...Catriver..post back.
Mar 02, 2007 | Kenmore 53582 / 53584 Side by Side...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
81 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
