Motorola Mobility RAZR V3i Cellular Phone Logo
Posted on Nov 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motorola v3i i have a motorola v3i that only shows the phone number for incoming calls, not the callers name and pic..help...this is very frustrating..i can't remember numbers very well.. also, when i receive an incoming call the ringer id is not working either..
Anonymous
Level 3:
Brigadier General:
  • Master 7,752 Answers
  • Posted on Dec 28, 2008
Anonymous
Master
Level 3:
Brigadier General:
Answers
7752
Questions
Helped
1415969
Points
13016
You would have to saved the contacts on your phone memory then assign ringer id to them and pics as well.
When there is an incoming Call, the display shows,
You must have caller ID provided by your local phone company for Call ID to work. This is an additional charge on your phone bill.
My incoming text messages show caller number and not ID why?
hello there,
Make sure you only have single entry for that person on your phonebook. Try to delete her or his name from your contacts to be able to know her duplicate.
Hope this helps.
2answers
Whenever i get an incoming call name of that
if the same no. is stored with two different names then it will not display the callers name.
Motorola v3i
you may need to reset and clear the phone then try again if that does not work then you can try a reflash of the firmware on the phone
Caller id Call Customer Service 1-8O5-465-751O To Fix Issue
First you need to verify if the caller id does that to all incoming calls, showing numbers only, or if it only does that to only numbers stored in directory. If it does that to all incoming calls then you need to check manual to see if there a setting to allow both name and number of all incoming calls. Either way you need to make sure caller id functions allows both name /number on display.
Motorola RAZR V9 Incoming Caller ID's UNKNOWN
its has been come from call center then u they dont show the no of caller
2answers
Can't receive incoming calls
same here... I unlock it but it doesn't received call
2answers
Caller ID
just go in the settings of ur phone and then phone setting or in contact setting
Caller ID
if you are putting 1 then the area code , just put in the area then the number and nt the 1 digit this should help
Incoming calls
both parties need to have caller id active
so if they are in your conntacts but don't have caller id opperating then the number won't be displayed
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
