My ice maker has begun to freeze up and stops making ice. Looks like the water is freezing in the supply line and therefore not filling the tray. It is also starting to freeze things inside of frig. Have turned it down to 1.5 out of 9. Use to have it set at 4 or 5. I bought and installed a new ice maker. Thought it was cheaper than a service call. ($80) But same problem was evident immediately. Ice maker model is a IC6. Frig is about 12 yrs old.
If it is only the fill tube that is freezing up, or getting full of ice, than your water valve is leaking (letting drops of water thru to your ice maker and filling the icemaker fill tube up and freezing). If this is the case, replace the dual water valve (part # 1071263) located in the back of the refrigerator, just follow the water line from your wall into the refrigerator. Make sure you turn off the water to the refrigerator and also unplug it. The dual water valve is the one that has two water lines, one going to the icemaker and one going to the water dispenser. On this model, I think you only have one water valve. On some you have two, the primary water valve and a secondary water valve (the dual valve). If this is your case, I would highly recommend you replace both. As far as the Refrigerator side freezing things up, I think that is a whole different issue. Please post back.
I have water that seems to be leaking from the icemaker and freezing up the ice in the bin, and also dripping onto the food in the freezer and making a complete mess of the freezer. I also have wanter that is leaking onto the floor in front of the freezer.
11 year old AMANA. Tray overfills by several ounces at each cycle and runs into the ice bin
