Canon PIXMA MP830 All-In-One InkJet Printer Logo
Posted on Nov 06, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
First start up of the day error code u140
The following ink tank cannot be recognised. This is on the black CLI- 8 tank.
Opening printer light on tank not lit. Removing tank and replacing normally resolves the problem. Is the fault in the printer or the a faulty ink tank chip ?.
Erica turner
Level 2:
Novelist:
  • Canon Expert 76 Answers
  • Posted on Sep 25, 2019
Erica turner
Canon Expert
Level 2:
Novelist:
Answers
76
Questions
28
Helped
134923
Points
309
Steps to Fix Canon Printer Error Code U140 Open the printer's cover first to remove the relevant cartridge gently. Now, switch off the printer by using accurate buttons that are there inside the printer. Make sure that you have not turned off the device's plug. Double check for the cartridge level to ensure that cartridges are installed accurately for the printer. Wipe out all the contacts that are there in the front side of the cartridge using a piece of tissue paper.Now, press the power button to turn the device on. Reinstallation of the cartridge is essential to ensure that it is returned to accurate black as well as in colored cradle.
To know more :https://www.canonprintersupport247.com/blog/fix-canon-printer-error-code-u140/
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Nov 07, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
852
Points
0
Said error 6A00 CODE
Canon mx350
Hello, your error is - U140 The ink cartridge
cannot be recognized.
A non-supported ink
cartridge is installed. Install
the supported ink cartridge.
Please check that you have the correct ink cartridge.
Hi, I refilled cartridge CLI-526M fromCanon Prixma MG5250 and I have the error U130. How can I resolve the error to reprint? Thanks.
FAQ: An Error Message Is Displayed on the LCD
Issue
If an error message is displayed on the LCD, take the corresponding action described below.
Cause
The following ink may have run out. Replacing the ink tank is recommended. U041 Print head is not installed.Install the print head.U051 / The type of print head is incorrect.Install the correct print head.U052 Some ink tanks are not installed in place. U072 / More than one ink tank of the following color is installed. U071 The remaining level of the following ink cannot be correctly detected. Replace the ink tank. U130 The following ink tank cannot be recognized. U043 U140 U150 The following ink has run out. Replace the ink tank. U163 There are no photos in memory card Contact the support center or service center for ink absorber replacement. Press OK to continue printing Ink absorber full. Service required Timeout error has occurred The device may be incompatible. Remove the device and check the manual supplied with the connected device An unsupported USB hub is connected. Remove the hub. B200Printer error has occurred. See the manual **** Printer error has occurred. Turn off power then back on again. If problem persists, see the manual
1helpful
Error code U150 The following ink tank cannot be recognized
First, make sure you have the right ink cartridges. Here are the right codes: CLI-8BK and PGI-5BK for black, Yellow - CLI-8Y, Magenta - CLI-8M, Cyan - CLI-8C.
If the ink lamp is off then an ink tank error has occurred. Try to remove the ink tank and re-seat it. Make sure you removed the plastic cover on the ink tank. If nothing helped, you need to replace the faulty ink tank.
1helpful
Canon pixma ip4300 black ink refill. BK and PB
The correct order of install a ink tank (From Left to Right):-
1. CLI-8 Black
2. PGI-5 Black (pigment)
3. CLI-8 Yellow
4. CLI-8 Magenta
5. CLI-8 Cyan
Else you can visit this link and type "correct order of ink tank" in enter your question space.
Good luck...don't forget to rate the solution.
Error code U071 , more than one ink tank of te following color is installed, is the message on the screen. This is not the case as each cartridge is different and correctly installed?
Error U071 : More than one ink tank of the following color is installed. U071.
Action : Confirm that the ink tanks are installed in the appropriate positions.
The machine will not print if the wrong type of ink tank is used, or if it is installed in the incorrect position.
Be sure to install the ink tanks in the correct order. The proper arrangement from the left is Black (CLI-8BK), Black (PGI-5BK), Yellow (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Hope this hepls.
Replaced the magenta cartrage. arror check Ink
The Error "Check INK U140"
Causes : Possible causes are as follows :
* The ink tank may not be installed properly (The lamp on the ink tank is off).
Install the appropriate ink tank.
* The ink tank not be compatible with this machine. (The lamp on the ink tank is off).
Install the appropriate Ink tank.
The machine will not print of the wrong type of ink tank is used or if it is installed incorrectly.
Be sure to install the ink tanks in the proper order. The proper arrangement from the left to right is Black - (CLI-8BK), Black -(PGI-5BK), Yellow - (CLI-8Y), Magenta (CLI-8M), Cyan (CLI-8C).
Replacing Tanks
1) Ensure that the machine is on.
2) Raise the Scanning Unit (Printer Cover) until it stops.
The Paper Output tray will open automatically and the Print Holder moves to the center.
Impoprtant : If the Scanning Unit (PRinter Cover) is left open for more than 10 minutes, The Print Head Holder moves to the right. Close and reopen the Scanning Unit(Printer Cover) to return the Print Head Holder to the center.
3) OPen the Inner Cover.
4) Press the Open button to open the Paper Output tray if it does not open automatically and remove the ink tank whoe lamp is flashing red fast. Do not touch the Print Head Lock Lvever. Remove only the ink tank.
Important : * Handle the ink tanks carefully to avoid staining clothing or the surrounding area.
* Discard empty ink tanks according to the locakl laws and regulations regarding disposal of consumables.
Note : Be sure to replace ink tanks one by one when replacing more than one ink tank.
5) Prepare a replacement tank.
a) Remove the new tank ink from its packaging, then pull the orange tape so that the protective film does not remain on air hole. Then remove the film.
b) Remove the orange protective cap from the bottom of the ink tank and discard it.
6) Install the ink .
a) Install the ink tank into the Print Head.
b) Press on the Push button on the ink tank until the ink tank snaps firmly into place.
c) Ensure that the ink tank clicks into place and then its lamp lights red.
Important : Make sure to install all the ink tanks to enable printing. The machine cannot be used unless all the ink tanks are installed.
7) Close the Inner Cover.
Note: Ensure that the Inner Cover is closed, Printing will not occur if the Inner Cover is open.
Hope this help. PLease rate my response.
Thanks
have a good day.
Canon PIXMA MP530 printer repeatedly getting LCD Error Message: "CHECK INK U071 5Bk". I have removed, reinstalled, reseated the 5Bk and all other ink tanks multiple times. Usually when this...
I have Canon M560 printer installed 8 months ago. I replaced the CLI 221 Magenta and CLI221 Cyan ink cartridges, won't work and got this message Error 1411. Tried repeatedly to reinstall the ink cartridges and still have this message coming back. Any solution you could offer? I would appreciate it. Thank you.
ben
Alarm light is lit -
Ok my printer is giving me the U140 message saying that ink tank cannot be recognized. The new ink tank is Cannon (not a off brand or refill). i think it is a problem with the chip reader port inside the printer not the ink tank chip. I feel this way because if you switch around the yellow and black 8 tanks, the printer accepts them without error.. soo if it was the ink cartridge i could be able to swap the black with the magenta and it should read it.
Need to change cartridge on ip3300
Greetings...
This Canon ip3300 has four ink tanks... PGI-5 Black, CLI-8 Cyan, CLI-8 Magenta, CLI-8 Yellow
Lift the front of the printer while the printer is on and the ink tanks will move to the center... the empty tank will have a blinking red light... the inks that are ok will have a steady red light... press the small tab in front of the ink tank that is blinking and remove... insert and press down the new tank and make sure the red light is on to show you have replace the ink correctly...
This should work, let me know if you have any additional questions...
Ed
old marine
old marine
ZJ Limited
ZJ Limited
