Question about LG 42LC2D 42 in. LCD HDTV
Sound altering on its own
I have an lg 32lc208 TV and am having sound problems. When it is connected to my sky box the sound tends to change on it's own from stereo to mono. It seems worse when I actually record onto my sky+ box. I have tried it without sky and it does the same but not so often. Can you help.
John
6ya staff
SOURCE:
Anonymous
  • 148 Answers
SOURCE: LG 42LC2D-EC NO SOUND ON HDMI
your setting for source of the audio is probably defaulted back to original setting in receiver. reassign audio input and problem may go away. it sounds like its not in the tv. i assume you have a receiver and are not trying to listen with speakers in tv. is this correct? if you are not using an amplifier, you may need to go to the tv menu to make sure the audio source is selected as the hdmi input. should take a bit to read thru the manual, but it ought to show you how to accomplish the correct settings.
let me know if it does not.
good luck
mark
Posted on Dec 23, 2007
jason
  • 905 Answers
SOURCE: LG 42PG6010 sky code
this might work 0206
if not check here http://www.satcure.co.uk/tech/digicode2.htm#contrib
Posted on Oct 24, 2008
rapanSF
Ken Kichi
  • 150 Answers
SOURCE: 42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
Posted on Nov 17, 2008
Anonymous
SOURCE: trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Posted on Feb 18, 2009
Techjoel
Joel
  • 79 Answers
SOURCE: remote control code
Television Direct Codes for Sky remote:
Goldstar 065, 405, 318, 245, 275, 037, 060, 391, 137, 459
Here are the codes for GoldStar which became LG. They might be the same.
Good luck,
Techjoel
Posted on May 09, 2009
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
Crackle Then Stop
Check the firmware on the tv. I would imagine youre connected with hdmi, and some tv's (lg, vizio mainly) have had firmware issues. check teh lg website for updates.
Jul 01, 2012 | LG 32LG30 32 in. LCD HDTV
I have a LG TV 37LC46-ZC with LG surround sound DVD Player/Amplifier LH-T550TB and a Sky HD Box. This used to work fine through the scart leads on the old sky box but since I changed over to HD Box I...
I know that's not all that helpful at the moment but I know that the no video out (to run a 2nd tv) that's there way of getting you to have a 2nd sky box I hope that is not the case with audio but it is a possibility ..try using phono plugs
audio out (RED WHITE omd audio in on your amp I have a look about and repost
Nov 26, 2017 | Televison & Video
I have a sky+ hd box connected to an lg 42LH300 tv through hdmi and an LG HT805SH home cinema through optical cable. Whenever i turn sky over i lose sound and have to turn cinema on/off to sound returns ...
One of the way to connect the whole system is using only HDMI cable version 1.3a. There is audio return channel built into the cable.So you do not have to connect the optic cable.
Sky box to TV using HDMI
LG HT805 to TV using HDMI. Even the Sky box audio will come back to the LG-HT through the audio return path.
Mar 08, 2011 | LG Televison & Video
I have an LG TV with an LG HOME CINEMA SYSTEM problem is: watch dvd/blue ray - video fine sound fine (through speakers) watch tv / sky -- video fine sound None throughspeakers on...
There are two things that I can suggest.
1-Test your optical cables to make sure they a good on a known working source because they are very fragile and break very easily.
2-Try to eliminate the use of optical output from tv to receiver. There may be a problem from the HDMI to optical conversion at the tv. Instead, try running the audio directly from the source to the receiver, and let the tv deal with video input only.
Hope this helps,
Good Luck.
Jan 07, 2011 | LG Audio Players & Recorders
Currently i have a sky hd box connected to my tv by a hdmi cable i want to connect my ipod into the sky box so i can play music videos ipod and sky box are close together and i don't want to connect ipod...
This isn't possible, the USB on the front of the Sky HD box is not active. I don't have any information on whether it will be in the future.
Your only option is to connect the iPod via TV or if you have a surround sound amp
May 21, 2010 | LG LH-D6230 System
5.1 sound from Sky hd through LG TV
link your optical cable from your HD box to your surround sound.
Then if you go into your HD services menu, press 4 then go to sound make sure its set to Dobly D
That should sort your problem out
Cheers
Little Dish Fitter
Feb 24, 2009 | LG 37LC7D 37 in. LCD HDTV
Nov 14, 2008 | LG 42LC2D 42 in. LCD HDTV
Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Jan 30, 2008 | Televison & Video
LG 42LC2D 42 in. LCD HDTV Logo
142 people viewed this question
Ekse
RONALD CARTER JR
