Hi Sir myself Suneet Kharbanda
sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection.
sir my email id is [email protected]
kindly mail me as soon as possible. my Pen Drive is Kingston DTI/512. and it has no any stick to remove write protected.
Thanks in advance.
i have the same error while deleting or formating my pen drive
My transcend 4GB pen drive
when deliting data it ask to remove the write protection
while formating the disk it shows write protected.
when copying data it ask to remove the write protect
Try this,
1.
Check out if the USB drive has a small swich for write protection. If its there try toggling the switch.
2.
Windows can all write protect flash drives. Check out this registry path,
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies.
You may find a key here on the right side by the name 'WriteProtect'. If it's not there this would not be the cause of problem. If it's there, make sure that the value is 0.
Please let me know if this does'nt work.
I am copy any file to pen drive error show this drive right protected WATS problem i am use win xp masses show any pen drive
Download "HP USB Disk Stogare Format Tool" (look at google) and format it in NTFS, not choose the quick format. It will work after writing a file bigger than 1,8gb.
Thank you sooo much..... "best solution" yes its working properly
= =", im sick of this,
many website teach me that method,
but it doesn't helps = =".
At REGEDIT,
1) i right click the "control"and cr8 new key name "StorageDevicePolicies"
2) after that, i cr8 a "DWORD" there name "WriteProtect"
3) i wonder it should change to "1" or "0"
*but i hav tried "1" and "0" but also the disk is still
"writeprotected"
4) im mad because i did this many time and it didn't help....
pls teach me.....
my email:[email protected]
if posible u could email to me please,
thank you.
Double-click on the WriteProtect value in the right-hand pane of Regedit.exe. Change the Value data from 1 to 0 and click OK to save the change. Close Regedit and restart your computer. Connect your USB drive again, and you should find it is no longer write protected.
kj
Right click device, go to properties, and uncheck the box that says Read Only or Write Protection. Double-check the manual for the universal unlock password. Best essay writing service reviews
Sorry this is also not useful for my pen drive.
Hi Sir myself Suneet Kharbanda sir i was used my pen drive from winxp to another os version. afterwards it gives me an error that disk is write protected. i tried to remove or format but again it gives me prob that it is write protected and not able to format. i used different solutions but unable to format or remove write protected. please help me. how can i remove this write protection. sir my email id is [email protected] ndly mail me as soon as possible. my Pen Drive is Kingston 4 GB it has no any stick to remove write protected.
SOURCE: Remove Write Protection
This seems to be the problem of most of us
these days and some of our readers who wanted to know the methods how
they can remove the Write Protected error from their USB drives like Pen Drives and memory cards.
What is Write Protected error and why it happens?
In the Write Protected error, we can’t write or copy any data in our flash drives and even can’t format the drive.
There are many reasons that cause this problem, let’s see solutions of them.
Solutions:
• First of all try to locate a small switch (if any, that you may have not noticed) at some place on the drive or memory card reader. This is the prime reason for this error. If there is one, switch it to the other side to turn the protection off.
• Yes I know this problem is also occurring these days without
this switch but not to worry. Just download this helpful software form here
http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
and run it to execute a “low-level format” on the drive. This software is quite handy and may take few attempts to actually remove the error.
• The problem can also be caused by some virus activity so just get it scanned by some updated good anti virus which may solve your problem.
• BUT if none of the methods listed above solves your problem then your pen drive might have gone corrupted, so just get it replaced.
Hope any of the methods listed above solves your problem.
Update 1:
After the low level format, you may need to “Partition the drive“.
Dont worry, partitioning a pen drive means allocating it its File
System and Cluster Size that was lost after the Low Level Format.
For that:
Click OK and the drive will be reusable after this.
Update 2 (Better Solution):
Follow the steps in this post and just put the value 0 (zero) in step 5.
This will surely solve your problem now.
rate me and vote me..
my 8 GB trancend pendrive has no problem with data less than 1.88 GB. But the time it is fed with more data after 1.88 GB, it shows 'Disk Write Protected. Please Remove Write Protection'. Sometimes it also has problem while formatting, or Cpying or deleting folders and files on it.Â
when i try to delete, save a file on my falsh drive, or format it, it says it is write protected. How do i remove the write protection?
my 4 GB trancend pendrive has no problem with data less than 1.7 GB. But the time it is fed with more data after 1.7 GB, it shows 'Disk Write Protected. Please Remove Write Protection'. Sometimes it also has problem while formatting, or Cpying or deleting folders and files on it.
i have the same problem, USB pen drive doesn't have the toggle switch.
I have also checked the registry, and i didn't found any entry by "StorageDevicePolicies"
Pls can u help me
Pls can u help me
Hi
I have the same problem as when try to format the removable disk error comes that the disk is write protected
pls anyone can help.
sir i was used my pen drive from winxp to another os version.afterwards it gives me an error that disk is write protected. i triedto remove or format but again it gives me prob that it is writeprotected and not able to format. i used different solutions but unableto format or remove write protected. please help me. how can i removethis write protection.
hi,
my transcend 8gb pendrive shows write protected problem during formatting.. i used the recovery tool frm transcend website. all files are deleted ... but am still unable to format it ... it s telling write protected. Suggest me a solution please. very urgent .......
please reply soon
please
When I insert memory card , I can not copy or paste. I got mesage : "
Disk is write protected ."
I cant see StorageDevicePolicies in regedit.
how can i remove write protection in my usb flash drive?
I was Not able to acces data from my 2GB Trascand pen drive.
Afterword while formatting message getting that 'windows was unable to complete the format.'
And I tried to acces through Linux also failed.
Also with 4 GB Trascand Pen drive "write protection errror"
Please Do Needfull Kindly.
Thanks In Advence.
when I insert in mu usb hub any removable divice like card reader, data traveler, or even my phone, the message comes out the disk is write protected please remove the right protection please tell me the solution
im also having same problem
Hi guys.....
i have same probem with kingston 4gb pendrive.
i tried many websites and many softwares. write protected error cannot be removed. i tried even lowlevel formatting with many softwares. it doesnt work. better replace ur pendrive
I AM TIWARI. i'm using windows vista home pc.i purchased a transcend pen drive 8gb.it is new.but
it shows ' Write Protected when i entered in cpu and whant to copy in it. Please writeme how can i Remove Write Protection'.Sometimes it also has problem while formatting, or Cpying or deletingfolders and files on it.
my pendrive is write protected solution for remove.
dear aashish,
your solution is not good enough wiil you please tell me the other solution
I cant able to copy,delete any data from my pendrive>its showing its write protected.Please help to resolve the problem
hello friends my transcend JF V60 is write protected can some help me to break the write protection??????????
sir,
when i transfer the data in my pen drive then i found a error message "the drive is write protect or use another disk" and i am anable to format the pen drive due to this message.my OS is windows XP SP-2
i can not delete or format my pendrive
write protected problem not formatting
not copy paste
i m also having the same problem... can anybody say , is there any solution to format the pendrive like flashing the mobile phone????
i can't write any thing in my pendrive, or i cant format it it shows same problem like "write protected" I used the "HP USB Disk Storage Format Tool" But it doesn't work. please tel me the remedy. my email id is [email protected]. pen drive is "Kingston make"
i have the same problem that the flash memory give error write protection
Hi everybody,
I have Kingston 32GB pendrive and tryed to copy the data into it, i am getting a " disk is write-protected". Can i have a solution for this error. If any body find solution for this please send it to [email protected] , please iam requesting friends.......
HEY MY TRANSCEND FLASH DRIVE WAS BE RPOTECTED AND I WANT TO FORMAT IT.
HOW CAN I?
