My tv has snow noise on all TV channels, but AV1 and AV2 plays good sound. decoder and DVD payer are perfect. on TV mode, all channels play snow noise, HELP!
First check cable wire or whatever is connected to set for channels--the leads are connected and wiggle them with set on to see if it clears up--could be a connection where cable wire is connected at end--loose connection there etc.
If tuner is bad causing this and you use a box for signal--most have rear audio/video outputs you can connect to a unused video/audio input on rear of set---bypass the tuner in the set and operate set that way changing channels on box instead of set.
let me know if you have questions or have more information.
SOURCE: Problem of Audio in Philips TV, Model - 21RF VardanSL
check option bites find it on crt or back cover to enter serv mode coll following comands
062596 menu or display the data will appear select options and set by vol and ch keys
SOURCE: our older model tv not flat screen, was playing
check the scart leads make sure they are all fully pushed in !
