I am able to move my cursor and the left works perfectly well, I am just unable to click on anything using the right side, after the problem began I went to settings and change my touchpad from right handed to left handed but the right is still not working, how do I fix this problem.
Did you check the settings for the left and right buttons under the mouse properties. Normally the left should be set on Click and the right should be set on Shortcut. If it's set to NONE then it will be inoperable. Better yet you can click the Default tab for buttons. Otherwise, it sounds like your touch pad needs to be replaced. The immediate remedy to this is to just go purchase a USB mouse and voila, you'll have the ability to left and right click.
SOURCE: drifting cursor
optical mouse (laser) will note work on shining surface (glass)...
PLEASE RATE ME ( FIXYA )............................
SOURCE: drfting cursor
This is a well known occurance with laptops and is not something you can fix. Occasionally the manufacturer will release a patch to try and help, but this is very rare.
SOURCE: Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
SOURCE: right & left click buttons not working
hmm quite interesting
has your laptop suffered some damage
i recomend you try to disassemble your laptop and check the connector for the touchpad.
dont know how try this site:http://repair4laptop.org/disassembly_acer.html
SOURCE: cursor moves, wont click!!
i think there may be two reason.1/some setting may be worang-go on conttrol panel and chose printer and other hardwere. inside click mouse and look setting.2/ your touchpad driver may not be working properly. stall it next.
