SOURCE: whirlpool ultimate care II topload washing machine
Well I'm going to do my best to fix your washer. First unplug the washer and turn off the water. If you have a shop vac take the drain hose out of the drain,and through the drain hose vacuum the water out of your washer. If you don't have a shop vac go to the auto parts store and buy a pair of radiator hose clamps . Then facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down. Now you will see the white pump and motor assembly. You should see two clips holding the pump to the motor pop them off, and pull the pump off the motor shaft. Now if you fell the need to remove the pump use the radiator hose clamp. take them and clamp the hose coming from the tub but its not necessary for the repair. Next disconnect the wiring harness from the motor (note the position of the harness for reassembly). Remove the two 5/16 inch screws from the motor clamps and pop the clamps off. Once that is complete, remove the motor put the new coupling on the motor and transmission shaft. I use a socket and a hammer
SOURCE: washer won't drain, makes loud noise
This problem, or some variation thereof evidently is very common with these Whirlpool Washers! I have same problem. So far, best I have found is at
http://applianceguru.com/forum2/5958.html#
diagnosis by someone who knows. What William Burk says there makes sense. However, to get to the drive block there's quite a bit of disassembly required. I am stopped because I cannot get the spanner nut off. Hope this gives you some help toward finding a more comprehensive answer
SOURCE: No water is coming in the washer before the agitator starts
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. these days the vast majority of washing machines are cold fill only and should give an error code if they can't take in water.
Most washing machines are controlled by software programmes these days and produce error codes if they don't detect the correct amount of water has been taken in within a set amount of time. The error code for not filling should be mentioned in the instruction book
Washing machine making a humming noise when trying to fill?
If the washing machine wont take in any water at all, plus you can hear a humming noise (not normally present), check that both your taps are turned on, or that the water supply hasn't been cut off in someway. A gentle humming from the back of the washing machine could be the water valves being energised and trying to take water in.
If water comes through at a decent flow rate then check the filter in the water valve on the washing machine. You can pull it out with a pair of pliers and clean it. However, this will only explain your fault if it is severely blocked up, which is rare. Be careful not to damage the filter with the pliers as they are often delecate and brittle. If you create a hole in one - even a small hole - it can let grit and even small stones through into the water valve and damage it resulting in possible flooding in the future if an obstruction stops the valve shutting off properly.
No adequate water supply coming through the hose?
If no water comes through the hose, or the flow is very slow, then the fault is in the plumbing or there could be a kink somewhere in the hose. If your machine was plumbed in using those self plumbing taps that clamp on to the copper water pipes then they do sometimes get clogged up and need the hole clearing. If this happens to the cold supply it can be achieved by turning the stop tap off first, but if the hot supply is blocked - which is the most likely of the two - then you have to turn off the cold supply and then drain the hot water tank by turning on the hot tap until the water is drained out (unless you know where the valve is to turn the hot water off in your water cylinder).
If your machine is plumbed in using the ubiquitous blue (and red) levers to turn the tap on and off they can commonly go faulty where you think you've switched it off or on but only the plastic lever has moved and it hasn't actually operated the valve inside the tap. This is typically caused when the red or blue plastic lever cracks. You can usually operate the tap using pliers.
SOURCE: Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
