I have a wireless connecter with Netgear which connects fine with the second computer i have however it keeps disconecting with the laptop I brought how do i fix this?
Maybe the wireless card in the laptop is no good or not strong enough to receive a good strong signal. Try sitting close to the wireless router and see if it loses connection. Does it connect at all and let you on the internet before it loses the signal? If it does not connect at all I'd say you might have an issue with the password or the type of wireless security protocol type you selected to connect with. For example there are different types of wifi security protocol types: (Ex. wep, wpa, wpa2) .
SOURCE: fujitsu laptop
Kev,
This seems to be a common problem. Remove and reseat the memory modules. If that doesn't do it, remove the hard drive and all but one memory module and try to bring it up. If this works, add the other memory module and see if the whole thing doesn't come up. If not, get back to me for more ideas.
Thanks!
Ron-
SOURCE: Fujitsu Siemens - Easy Launch Keys - Wireless
go to network connections, right click on your wireless adapter and click enable or connect. Or go to my computer>right click>properties>device manager> hardware tab, look in list for wireless adapter, right click and select enable.
SOURCE: borgan
are u sur it has wireless
if u do when u turn on your laptop press f2,or f8 where it show computer info. and look through them and find a wireless adapter or somthing like that and check if it is on
if u need more info reply back
SOURCE: cant switch my wireless on
do you have an Fn button(function) the letters Fn are usually a different colour.If so you need to hold it down and then press the wireless button.The wireless button should have the same coloured letters or symbol looks like an aerial
good luck
any prob let me know
SOURCE: no internet connection
re-install all network drivers or uninstall all network drivers and install again the drivers
