2003 honda 600rr ignition diagram, broke the key off in tank fuel door want to bypass ignition three wires red, red black, pink? Which wires get spliced together, which is ground, just a stunt bike
SOURCE: fuel petcock
The petcock is what the fuel flows through when it comes out of the gas tank. It probably includes: * A switch with positions for On, Off and Reserve. * A fuel line going to the carburetors. * A vacuum hose attachment which attaches to a carburetor which tugs on a rubber diaphram to let gas flow through. * An overflow/drip valve from the vacuum area. It's located right under the tank on the rear/left side.
SOURCE: honda cbr 600 rr 2005 fuel tank removal
I had an 07, I had to remove the lower and side fairings and then the bolts are visible, dont just lift it up because wires and the fuel line will be connected and tight. When you lift it, lift easily so you dont just rip everything, you should be able to lift it high enough to disconect the wires without damage.
SOURCE: lost cbr 600 f4 key?
http://www.carlsalter.com/motorcycle-manuals.asp
get a free pdf service manual for your bike here. you should find out how to remove the ignition. or if you have a seat lock that is easier to remove take that to a locksmiths to get new key cut
SOURCE: How do you remove the ignition switch from 1999 Honda CG125
Usually large cir-clip or nuts an bolts, why don't you get one from a breakers? anyhow there's a bit off stuff to come off it before you'll see what your doing, make sure its possible to remove it with or without steering lock on or off. The barrel can usually be separated from the switch but be careful not to take summit apart that wont go back again. A clever engineer would be able to use an old CG125 key and make your barrel fit that key! But alas i'm not blessed with a good locksmiths skills. Good luck - the Yeti
SOURCE: my honda cbr 600rr 2005 will not start the hiss
1. Obtain a new transponder key.
2. Grind the key in accordance with the shape of the original key.
3. Apply 12V battery voltage to the ignition pulse generator lines of the engine control module (ECM).
4. Turn the ignition switch ON with the original key. The immobilizer indicator comes on and it remains on.
*The code of the original key is recognized by the ECM.
*If there is any problem in the immobilizer system, the system will enter the diagnostic mode and the indicator will remain on for approx. ten seconds, then it will indicate the diagnostic code (page 20-5).
5. Disconnect the red clip of the inspection adepter from the battery positive (+) terminal for two seconds or more, then connect it again. The indicator remains on for approx. two seconds, then it blinks four times repeatedly.
*The immobilizer system (HISS) enters the registration mode. Registrations of all key except the original key inserted in the ignition switch are canceled. (Registration of the lost key or spare key is canceled.)
NOTE:
The spare key must be registered again.
6. Turn the ignition switch OFF and remove the key.
7. Turn the ignition switch ON with a new key or the spare key. (Never use the key registered in previous step.) The indicator comes on for two seconds, then it blinks four times repeatedly.
*The new key or spare key is registered in the ECM.
*If there is any problem in the registration, the system will enter the diagnostic mode and the indicator will remain on for approx. ten seconds, then it will indicate the diagnostic code (page 20-6).
CAUTION:
Keep the other transponder key away from the immobilizer receiver more than 50mm (2.0 in).
8. Repeat the steps 6 and 7 when you continuously register the other new key.
NOTE:
The ECM can store up to four key codes. (The four keys can be registered.)
9. Turn the ignition switch OFF, remove the inspection adapter and connect the ignition pulse generator connector.
10. Turn the ignition ON with the registered key.
*The immobilizer system (HISS) returns to the normal mode.
11. Check that the engine can be started using all registered key.
If that doesn't work,You will need to go to a dealer and have the keys reprogrammed.
