Motorola Mobility RAZR V3m Cellular Phone Logo
Posted on Nov 05, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Extending my ring tone, it is too short
Extending ringtone time.
It is too short resulting in many missed calls by the time I get to the phone.
Anonymous
Level 2:
  • Expert 85 Answers
  • Posted on Nov 14, 2008
Anonymous
Expert
Level 2:
Answers
85
Questions
Helped
31117
Points
185
Standard time is 15 sec. try going to your voicemail and changing or turning it off
1helpful
Where do I change ring tones? I don't want to
Press Menu
go to Settings and tools
then Sound Settings
then Call Sounds
then Call Ringtone
select the one you like.
Other way is on each contact, edit ringtone for that contact.
Ringtone
Unclear if you're using the TMobile ring tones or some that you have downloaded (or created). BION, I got longer ring times by using longer ring tone recordings. (I got mine from free sites on the net, most tones created by people from their music collections.) If you are using ring tones that aren't from T-Mobile, switch to a TM ring tone and see if that makes a difference. (If it does, then shop around for some new ring tones - the old ones were causing a problem.)
Another possibility is to check settings/phone/auto answer. Be sure this is set to "never." Also check Call Barring. Try having your blocking of incoming calls "off."
And last: put profile on "vibrate" and call yourself. Do you get more than one second of vibration? If you don't, then it's probably a phone malfunction, but if you do, it's a ring tone problem. Fairly easy to deal with. Good luck!
1helpful
4answers
Rings that come with phone are short
It sounds like it's not the fact that the ring tones are short, but that your device is set to go to voicemail in a short amount of time. Call your service provider and they can set the time to a max of 30 seconds before the call is sent to voicemail.
Volume
Ringtones that come with LG Vu just arent loud enough. Try downloading FREE ringtones from -myxertones.com-you can find many that ring REALLY loud!
1helpful
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Ringtones on my moto krzr
did the tones come pre installed on the phone? why dont you try using mp3 ring tones? download mp3 songs on your phone, then you can set them as ring tones. they work much beter than ordinary ring tones
2answers
6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Mar 25, 2008 • Nokia 6600
Assigning ringtones to a profile
If you set the profile ring tone to OFF. Then select a contacts' number and assign it a Ring Tone. When that contact calls you the Ring Tone you assigned will ring.
If you select the same Ring Tone for all your contacts in a group they will all sound the same when they call.
Or select the same ring tone for a profile, but cancel the Tone you assigned to the contact(s).
Can only use 1 ringtone at a time on my Motorola v3.
Are your contacts off the SIM? You cannot assign a ringtone to a SIM contact that is different than your general ringtone. If it is a SIM contact save it to your phone then you should be able to assign a distinct ringtone.
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
