Question about Broan-NuTone Best by Broan 30quot; 500 cfm K41 Series Wall Mount Chimney Hood - K4130
I have a Best K41-1 and my variable speed on the blower does not work. It only works on high speed when slid into that position. What could be the problem?
    New Friend:
I have the same problem (again) but with the lights not working also so something else is going on. The usual fix for the fan on high issue is to replace the switch assembly (SB06105117). It's an $80 part. This worked for me the first time it happened. If you are handy then it's a 1/2 hour project - turn the power off at the breaker.
Posted on Feb 19, 2013
6ya staff
SOURCE:
Noise on high speed
Is it the original size motor? It sounds like it could be to many CFM for the size of the duct causing back pressure when the blower goes into high.
Apr 08, 2014 | Goodman Manufacturing Goodman MBVC2000AA...
The blower doesn't work for the a/c
Check fuses, then the relay. Fused power to the lower speeds, and a relay sends power to the fan for high speed. Some cars have an electronic blower motor for a variable speed system. The motor could be bad, or the motor board could be bad, if you have a variable speed blower motor. Very expensive to replace. 250 to 400 dollars. good luck.
Aug 16, 2013 | 1998 Lincoln Mark VIII
Heater only works on low only it does not blow much hot air air conditioner also
High and low speed on demand is delivered by the same blower. Blower is controlled by the blower regulator. When a regulator is bad, a variable speed is not available. Replace the blower regulator will take care of the problem. Good luck.
Nov 20, 2010 | 1999 Ford Contour
Toyota 2000 camry fan only working on high speed
The blower motor resistor pack is defective and must be replaced. The resistor pack controls the variable speeds.
May 01, 2010 | 2000 Toyota Camry
Variable fan was only working on high for ac now not blowing
if fan speed is working only on one speed it is most likely the blower resister,located in the blower box
Jun 28, 2009 | 2001 Jeep Wrangler
I have a 2001 chevy suburban. Low speed (1&2)blower not working but the high one works. How do I fix this problem and the location of the part if I need a new one. Please help.Thanks. Isoa
beleive it or not it is the high speed blower relay ... has one setting for high and a variable setting for all lower speeds ... usually found on the firewall near the blower motor
Mar 18, 2009 | 2004 Chevrolet Silverado
Heater/ Air Conditioner Blower Motor
you should relist under lincoln continental, not refrigerators. If you have electronic temp control, you should not have a resister. You should have a bower motor speed controller.
here's info for 1996 system. I don't have 1995, sorry.
A/C Blower Motor Speed Control
The A/C blower motor speed control (19E624) is located under the A/C evaporator housing, to the left of the blower motor (18527).
  • The function of the A/C blower motor speed control is to convert low power signals from the EATC control assembly to a high current, variable ground feed for the blower motor.
  • A/C blower motor speed is infinitely variable and is controlled by the electronic control assembly software and A/C electronic door actuator motor position.
  • A delay function provides a gradual increase or decrease in blower motor speed under all conditions.
Blower Speed Override Thumbwheel
Rotate the blower speed override thumbwheel more than 10 degrees to turn OFF the AUTOMATIC blower indicator and provide manual control of the A/C blower motor speed.
  • The display will show FAN and a fan symbol.
  • Rotating the wheel fully down against its lower stop locks the blower motor (18527) at its lowest speed.
  • Rotating the wheel fully up against the stop, locks the blower motor at its highest speed.
Press the AUTOMATIC button to resume automatic A/C blower motor control and remove the FAN and fan symbol from the display window.
Jun 27, 2008 | Continental Fish File Refrigerator - 1 Row
Kitchen Ranges Logo
359 people viewed this question
Top Broan-NuTone Kitchen Ranges Experts
Marvin
Marvin
Paul Bade
Fahr Quad
Are you a Broan-NuTone Kitchen Range Expert? Answer questions, earn points and help others
