SOURCE: System error E000
Press the "additional Function" key
Press the # key
Press F3 key until "Printer" shows up.
Press "OK" key
Press F3 key until "Printer Reset shows up
Press "OK" key
Press the * (star) key
Turn printer OFF then back ON
1. Hit Additional Functions Key 2. Hit # key 3. Arrow to number 7, Printer and hit Set 4. Arrow to number 4, Printer Re-Set and hit Set. 5. Yes, re-set printer (hit minus key - back arrow). 6. Unplug the machine and plug it back in. This just worked for me on a D860
E000 is a high temp. error. My first advice would be to atempt to clear it in service mode:
If this does not help, on most units you have to start looking at your Fixing Assy. or Thermistors. Make sure that you do not have a piece of paper wrapped around Upper Fixing Roller or and other foreign substance in that area. However, on this one, I would recomend replacing Fix Assy. as a whole if you can, FG6-8326-000 (for s/n starting with MQT/MQV/MRV/MRW) or FG6-8325-000 (for all other s/n). Don't see p/n for Thermistors. Also, heard of alot of other board and p/s issues with this model that can cause E001-E004 errors. See if you can clear it first. Good luck. Let me know how you make out.
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
SOURCE: canon mfp 4320d system error e255
dear sir,
this is manjunath my canon laser jet printer it's given problem the problem is system error E255. it's shown on the printer.. plz given the sulation... my contect number is +91 9916062560
