This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
- Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
- If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
- When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Oven went set to Circotherm does not heat up when temperature selector engaged.Light in oven,fan assistance come on but no heat.Grill still operates.Have switched Oven off at mains,reset several times.Red light that normally goes off at 180/190 just stays permanently on red even when temp selector set to max
oven popped and tripped fuse and now won't work
The gas hob and automatic lighting works also
