Sorry, it's not an answer, but I have the same problem right now with the actual filter. Replaced it once, but now won't come off. Will replace with my BLUE cap, once filter is off. How did you fix yours?
Are you sure what you're turning is a bypass cap? KitchenAids don't usually have bypass caps.
If it is a bypass cap though, make sure you're turning to the left. It could be tougher because it's under pressure, so turn the water off going to the fridge and run the water out the dispenser if there is any.
SOURCE: HOW TO YOU REMOVE THE BYPASS PLUG IN FRIDGE SO WE
push it in and turn it counterclock wise and pull it out
