I was playing video games on my T.V and it suddenly shut off. I tried turning it back on again and the power immediately shut off after about 2 seconds. I tried this multiple times but to the same effect. The Green power light comes on so i know the Tv is getting power.
I'm getting a code 2-2 ,what do I do ?
Unplug the unit from the outlet for at least 1 hour and check if the symptoms persists. If yes, check if the unit can give an error code by following the steps below.
- Power on the unit and wait until the initialization takes place.
- Press the front panel "Input" and "Menu" buttons at the same time and hold it for 5 seconds, it will activate the error code mode. LED flashes a two digit error code. Example, if the error code is "22" the LED will flashes two times pause and then flashes two times and will repeat the error code for 5 times.
"12" means no error has occured.
Please let me know what will be the result to assist you further.
Regards,[email protected]
