I just bought this new, when i set it up to do a wash and then drying cycle it just keeps doing the wash cycle over and over.. i unplugged it thinking maybe its a tech problem.. that didnt help.. the dryer appears to be working ok as i set it in spin cycle with dryer after it and all worked fine.. so its something to do with the washing..
i plan on phoning the place i got it on monday.. but wondered if it was a simple fix or something..
Thanks..
SOURCE: indesit widl126s
Suggestion: Possible your outlet filter is blocked; this needs periodic cleaning, depending on your usage. Clean this out and re-fit. Refer to your users' manual re. where the filter is....
SOURCE: I have a indesit WIDL126.
I have had the same problem and this has worked in the past:switch off the machine, then unplug it at the mains. Leave it unplugged for about a minute then plug it back in and try again.
SOURCE: indesit widl126s humming noise on spin cycle and
Your drain filter is clogged with debris. Usually small items like
dirt, paper, money, and much more. Clean the filter and you should be
set to go.
I hope this information allows you to resolve this issue. If you need
further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take
just a moment to rate this post....thanks!
SOURCE: My Indesit WIDL126 washer/dryer doesn't dry clothes
You have an air flow problem. This usually happens when the exhaust pipe/vent gets clogged. Clean/inspect the vent outlet, the pipe, the inlet, and the filter/lint catcher area.
Improper air flow prevents the moisture from being vented out of the dryer.
