Stopped producing the ice. there is a red light blinking on the right side of the freezer
SOURCE: KitchenAid Side By Side no ice
check the ice maker, the motor module on these is real bad about the shaft snapping. take out the icemaker and remove the white cover. if you can take the round gear off then the shaft is broken you can probably find the other piece in there if it didnt fall out when you opened it up the module is easy enough to replace make sure the heater on the mold assembly is still good
SOURCE: Ice maker will not make ice. Red light blinks
I have a kitchenaid with the same problem. Red light blinks twice when open is normal. Hold the flap down and the red light will be on.= normal= optics are working. If the ice rakes rotate, module is probably fine. Check the simplest solutions first, defrost the freezer in case the icemaker water nozzel might be frozen. That solved my problem. I then increased my freezer temp by a couple of degrees and so far, no problems.
Good luck.
SOURCE: ice maker is not making ice
Even though the water dispenser is OK you need to make sure the tray(s) in the ice maker are filling. The filter valve, located to the rear of the ice maker can freeze over and stop water flow. Check the supply line for the ice maker, it may be separate from the water dispenser.
SOURCE: Ice Maker Stopped working. Kitchen Aid Model
Here are some basic tips for ice maker troubleshooting...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
SOURCE: KSRS25SS icemaker stopped making ice.
Here is a tip that I wrote about the reasons why ice makers do not work.
heatman101
